Scion XB same engine
Discussion in 'Gen 2 Prius Accessories & Modifications' started by priprichan, Jun 7, 2018.
  1. priprichan
    priprichan New Member
    Western Springs
    First gen Scion xb uses the same engine. I'm wondering if some of it's performance mods are compatible with second gen prius' anyone know or try?
    SFO likes this.
  2. Tideland Prius
    16,155
    It runs a different cycle - the 1G xB uses the Otto cycle and the Prius uses an Atkinson cycle.
    It might be easier to just simply swap out the engine first before adding performance mods.
  3. egg_salad
    egg_salad Active Member
    545
    426
    Las Vegas, NV
    It's almost the same engine. The Scion xA and xB, as well as the Toyota Echo and early Yaris, use a 1NZ-FE engine.
    The 2G Prius uses a 1NZ-FXE engine.
