Scissor jack for 2024 Prius Prime
Discussion in 'Gen 5 Prius Accessories and Modifications' started by fdgibbons, Jan 9, 2025.
  1. fdgibbons
    fdgibbons New Member
    Santa Rosa, California
    2024 Prius Prime
    XSE
    I’m new to the forum and this question may have already been discussed. I bought a new Prius Prime three months ago and really like it so far. As we all know, there is no spare tire, but I would like to be able to pull a flat tire off if I needed to on the road. Since I need a jack to do this, I would like to find an after market one that would fit in the styroform slot in the trunk but don’t want to pay a dealer over $200 for one. Does anyone know of an aftermarket jack that would work?
  2. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    The official set should be under $100, according to OEM spare tire install | PriusChat
    The kit you should be buying is a sensible price. The individual parts are more expensive.
  3. Hammersmith
    Hammersmith Senior Member
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    KMO is correct. You can currently get the tool kit(jack, jack handle, lug wrench) for $91.71(inc. free shipping). If you wait for a bit, you should be able to get it for about $73.37 during a 20% off sale.
    Here's an example of one dealership with the max discount, but there are probably others that are closer to you that have the same 31% off:
    Box Set, Jack
    Templeton likes this.
  4. Starlift
    Starlift Junior Member
    Western NY
    2024 Prius Prime
    XSE Premium
    Can anyone tell me what fits in the OTHER styrofoam cutouts now that I have the jack and tire tools??
  5. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    Whatever you like :)
    But I did this a while back in another thread, based on all the official sources I could find:
    Plus the trays also have little cut-outs apparently intended to hold the guide pin and wheel bolt socket the car was going to need before the last-minute switch from wheel bolts to nuts, due to the problems seen with the bz4X. Could still use it for a special locking nut thingy.
    Window grommet explained here: Gasket for power cord through rear side window | PriusChat
    #5 KMO, Mar 11, 2025
  6. Mendel Leisk
    41,880
    Funny, the one thing not identified in the above, the temp spare in Type C.
  7. KMO
    KMO Senior Member
    2,009
    731
    Finland
    2023 Prius Prime
    Sorry - that's the big round thing under the window grommet.
    Apologies for the inconvenience...
  8. Mendel Leisk
    41,880
    Was that your graphic?
    I was assuming it was toyota's, and they purposely leave the spare unnoted,, thinking the less said the better.
  9. AddMoreGas
    AddMoreGas Member
    88
    Dallas
    2024 Prius Prime
    XSE
    The pinch welds at front and back are marked and easy to find. Work perfectly with a quickjack with pinchweld blocks....
    Julio_E likes this.
  10. Hammersmith
    2,315
    2,361
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The base line drawings are from the manual. The coloring and labeling are from KMO.
  11. Mendel Leisk
    41,880
    Ah, apologies.
