Scoring on brake discs/rotors.
Discussion in 'Gen 4 Prius Main Forum' started by The Professor, Oct 3, 2019.
  1. The Professor
    The Professor Senior Member
    598
    809
    UK
    Excel
    My Prius had its second annual service today. Everything was fine, other than they noted deep scoring on all 4 of my brake discs. See picture. I was pretty shocked at how bad and deep the scratches are. On all other cars I've ever owned, the discs are smooth. The discs also have a pretty deep lip on them (where they've not worn away). At this rate, I'll need replacements in a couple of years.
    For what it's worth, I'm a pretty gentle driver. I try to use regen for braking as much as possible, and brake very gentle unless it's an emergency.
    Any ideas what could be causing this and how to prevent it?
    I asked the guy at the dealership and he replied "It's because it's a hybrid. The Prius first uses engine braking to slow down, and then the gearbox. This heats up the brakes a lot and that's why you're seeing the scratches." o_O:confused: Fascinating...
    49,374
    hard to tell, do they all look like that? if it was one, i could see a foreign object getting caught or something.
    how many miles on her? i am also a gentle brake, and they look good at 66,000. i wonder if they have changed materials?
    The Professor likes this.
  3. davecook89t
    davecook89t Senior Member
    1,057
    789
    Washington State, Florida
    Four Touring
    Mine look nothing like that, probably because (likely) I have fewer miles. I also see some rust on yours. Do they use a lot of salt on the roads where you are in the UK?
  4. hill
    8,155
    if you bought the car used, it could be assumed the prior owner did a lot of hard braking & ran the pads all the way down until metal-on-metal was contacting. That's really the only way that rotors ever get that scored, other than poor heat treating of the rotors. Did the dealer take this picture? If so, and because his rationale was so false, I would suspect dishonesty at the service center. Other but of course - that never happens
  5. The Professor
    598
    809
    UK
    Excel
    Thanks or the replies...
    They all look that bad. 18,500 miles. 2 years old.
    During the winter months, yes. But there hasn't been any salt on the roads here since maybe last March.
    It's an ex-demonstration car bought directly from the dealership. It had, I think, 1,600 miles on the clock. Pretty sure it's the original pads as they still have 10mm on the rear and 8mm on the front (12mm when new I think?).
    I took the picture.
  6. bisco
    49,374
    hmm... ex demo, that might explain it. any idea if they were inspected prior to purchase?
    did they give you pad measurements?
  7. davecook89t
    1,057
    789
    Four Touring
    Ok, not many miles on your car either. The rotors on our Gen 2 look better than that, and it has 278k miles. I know the pads were changed on our car right before I bought at 211k, but there is nothing on the invoice about the rotors. I don't know what advice to give you. Maybe others will weigh in.
  8. Mendel Leisk
    38,647
    How are the pads? :confused:
  9. The Professor
    598
    809
    UK
    Excel
    They look ok. Still plenty left.
    I wonder if it's environmental. I do travel along a gritty/sandy/dusty road at the top of a big hill quite often. Maybe stuff is getting jammed between the pads and the discs...
  10. The Professor
    598
    809
    UK
    Excel
    They didn't give me pad measurements when I bought it, but it's 10mm at rear and 8mm at front at the moment. That was from the service but I've measured them with calipers just now and it's correct. They appear to be wearing evenly.
    The thing is, I don't recall seeing this scoring before. I'm sure around a year ago when I was having the tyres replaced the discs were fine. It also wasn't noted in the previous service.
  11. ChapmanF
    15,435
    To my eye that looks both scored and very shiny/glazed, as if the brake was dragging. They typically last a long time, but some oddball problem can sometimes crop up between inspections, and do some damage unexpectedly quickly.
  12. bisco
    49,374
    this sounds plausible. have you, ever since purchasing?
  13. The Professor
    598
    809
    UK
    Excel
    Have I ever what? :D
  14. bisco
    49,374
    been going over that hill?
  15. The Professor
    598
    809
    UK
    Excel
  16. bisco
    49,374
    maybe that's not it then
  17. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Sounds like the dealership chap needs to study LOGIC - that made no sense.
  18. alanclarkeau
    7,044
    7,584
    There was another member a few months ago - she had much the same problem, can't recall the outcome?
  19. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    The glazed look on those look like the brakes have been overheating, maybe binding. What's the fuel economy like, any change in the last 12 months ?
  20. The Professor
    598
    809
    UK
    Excel
    They are shiny indeed. Getting about 60 over last month. That's very normal. Felt discs just now immediately after a 1 mile journey and they're cold.
