scosche line output converter help needed
Discussion in 'Gen 2 Prius Audio and Electronics' started by Lavalamp, Sep 11, 2010.
  1. Lavalamp
    Lavalamp Junior Member
    34
    Tallahassee, FL
    After lots of searching and reading I found to add subs/amp to my car I needed a line output converter, and did lots of searching to find the correct diagram for my car.
    I connected everything up using what i believe were the right wires (red, black, yellow, white) and connected the "common ground/factory amp/line out" wire to a white ground wire (not sure if this was right but didn't know what else to do.
    also my converter seems to be a little backwards, the manual that came with it show the rca ouputs on the opposite side as the inputs (A1/A2/A3...), whereas mine are on the same side...
    but so everything is connected and my subs aren't amking any noise, any ideas?
  2. svitale75
    svitale75 Prius Addict
    39
    What is the adapter model? I have a Scoche as well and had no issues hooking it up. Also what model/year is your Prius? I have some wiring diagrams that might help you on this. If your adapter has pots (potentiometers) make sure they are anywhere else than 0 :)
    The common ground can be any ground wire.
    skorpyo33 likes this.
  3. Davids23
    Davids23 New Member
    Burbank
    I needed help to connect a coverter to my prius ii 2012 any ideas of what to buy or suggestions thanks
    Much appreciated
  4. skorpyo33
    skorpyo33 Junior Member
    30
    Sebastian, FL.
    Did u hv jbl speakers in your prius when hooking up that Scoche? I dont. 2010 prius. Was thinking about getting it. And hv u had any problems since?
  5. DaButtDr
    DaButtDr New Member
    pennsylvania
    I have a 2013 Prius with the JBL audio system. I am attempting to add an additional amp and sub to the rear of the vehicle. I cant seem to determine what wires to connect to for speaker output on the backside of the head unit. I am using the Scosche LOC2SL model. Any help would be greatly appreciated!
