Scraping/Squealing noise
Discussion in 'Prime Care, Maintenance and Troubleshooting' started by DMikeAle, Feb 25, 2018.
  1. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Odd noise from my wife's 2005 - youtube video in the link above. Just over 108k miles. Any ideas?
    48,983
    ow! my ears!:eek:
    welcome, is the serpentine belt okay?
  3. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Runs true, also - no deviations from side to side on any of the pulleys.
  4. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Thanks for the welcome! And yes - belt seems ok. No cracks, not dried out.
  5. bisco
    48,983
    does it only happen with engine running? iow, driving ev?
  6. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Correct, only with the engine running - nothing heard otherwise.
  7. bisco
    48,983
    are there radiator cooling fans? i can't remember.
  8. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    There are, but the sound seems to come from further back of them - closer to the belt.
  9. bisco
    48,983
    have you looked underneath? maybe some of the plastic cowling is vibrating.
  10. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Just double-checked for pulley movement, now I'm seeing quite a bit of movement out of the water pump pulley. Tightened bolts on top, still saw the movement - could a bad bearing be the cause? Seems like that could produce that noise, right?
  11. bisco
    48,983
    absolutely, good catch.
    Raytheeagle likes this.
  12. DMikeAle
    DMikeAle New Member
    Hawaii
    I
    Just to follow up, that was the culprit! The internal fins had started to grind, hence the noise. Replaced the whole pump.
  13. bisco
    48,983
    thanks, well done!(y)
