Scratch/dent across two doors. Difficult repair?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Badass, Jan 4, 2016.
  1. Badass
    Badass Junior Member
    England
    My wonderful wife, under some seasonal duress, managed to pull out of our driveway without sufficient attention paid to her surroundings and scraped the left hand side of the Prius (2010) against the front right corner of the bumper on the Volvo.
    As a result there's now a long scratch (and some denting) down both left hand doors of the Prius, with a token amount of paint transfer on the left rear wheel arch.
    My local body shop had a look and said that due to the thin nature of the metal of the Prius doors, they couldn't do an effective repair, necessitating the purchase of two new doors to do the job properly. They were honest and open about how I might not be happy with the repair if they don't do this.
    My question is has anyone had similar issues repairing light body damage on Prius doors?
    #1 Badass, Jan 4, 2016
  2. catgic
    catgic Mastr & Commandr Hybrid Guru
    586
    140
    HTTP 404 Not Found
    Badass - Based upon what I see in your photos, that damage to the doors is very minor and can easily be repaired using body filler. The "...due to the thin nature of the metal of the Prius doors, they couldn't do an effective repair, necessitating the purchase of two new doors to do the job properly" assessment-estimate given by the body shop is suspect. Get other repair quotes from other shops.
    #2 catgic, Jan 4, 2016
  3. Caniac
    Caniac Active Member
    232
    164
    Happy Valley
    Not being a smart@ss but, have you seen the damage with the car washed? It's really hard to tell the extent of the damage done.
    solrunner likes this.
  4. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I would try another repair shop, that damage looks repairable without door replacement.
  5. roamerr
    roamerr Member
    135
    43
    Winston-Salem, NC
    I can't tell the damage but am certain it can be repaired with a light coat of filler. My wife backed into a friends Ford Focus in the exact same doors several years ago. Quote without replacing doors was $1100. Quote replacing doors was $2500. (2 different body shops).
    iPhone ?
  6. BZzap!
    BZzap! Senior Member
    1,607
    877
    Any reputable body shop can source used panels. There are plenty of them out there. It would cut costs by about 1/2. Your chance of finding the right color is also a good probability. Have a look on eBay. A complete door ranges about $600 or so. The only labor you would be for installation.
  7. JC91006
    16,482
    8,400
    This car is 6 years old and a repair would be the best option.....even if it doesn't turn out to be absolutely perfect. I don't see a problem using filler, the replacement door thing is crazy for this damage
  8. BZzap!
    1,607
    877
    ^^^ Agree. Best option. Better yet, just drive it.
  9. Mendel Leisk
    38,720
    ^ Plus 2, for conventional repair, without door replacement. One reason, you can get into new problems with door replacement, at least that's been my experience: the bodyshop could NOT get the doors aligned, closing easily.
    Shop around, check reviews. A good bodyshop will repaint the entire side, and feather out the paint in such a way that you can't see a transition.
  10. JC91006
    16,482
    8,400
    Mendel is correct. I recently replaced 2 passenger side doors on my 2008. I bought used doors from a salvage yard and put them on. Although it's fixed, it's not aligned perfectly and doesn't look perfect. But since my car is from 2008, I really didn't care.
  11. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Reskinning the doors is another option. Wash the car so the damage can be inspected and get some more estimates, including the dealer.
  12. qdllc
    qdllc Senior Member
    1,370
    399
    This. I've had it done on another vehicle where it was cheaper than a replacement door. Thickness of metal should not matter unless it would hinder cutting off the old and welding on the new.
