Scratch In The Hatch
Discussion in 'Prime Main Forum (2017-2022)' started by EyePrime, May 2, 2018.
  1. EyePrime
    EyePrime Active Member
    268
    115
    Ottawa, Ontario, Canada
    2018 Prius Prime
    I'm so mad at myself:mad:
    So I was opening my garage at the same time as the hatch was opening. (We have a Low Garage Cause of living room above) It made a horrible sound and there is a pretty deep scratch.:cry:
    Anyone have an Idea to fix the scratch.
  2. hill
    8,192
    Same thing happened to us near the charge port. We just left it so we won't have to experience the same shock later on.
    49,511
    we've all done it. get some touch up paint and see how it looks. carbon fiber, right?
    EyePrime likes this.
  4. EyePrime
    268
    115
    2018 Prius Prime
    Yep but it was a scratch on the outside
  5. bisco
    49,511
    outside is aluminum or steel?
  6. Tideland Prius
    16,159
    CFRP or traditional plastic, depending on which part he scratched.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    so........is the scratch on the hatch.............a match?:p
  8. hill
    8,192
    Only if the paint comes from the same batch
    Since2002 and priuscatprimeguy like this.
  9. EyePrime
    268
    115
    2018 Prius Prime
    Close to the license plate
    If this was my car it would be right here
    Were was the scratch? was it a key?
    #9 EyePrime, May 2, 2018
  10. hill
    8,192
    I think one of us dropped the J plug against it. No scratch, but a small dent.
  11. EyePrime
    268
    115
    2018 Prius Prime
    Ouch, Have u tried... Well... Ummm... A... plunger... to... pop out the dent. There are many youtube videos on this method.
    Ummm u may want to clean your car after... don't want THAT on your beautiful Tesla? Or is it a Prime
  12. Tideland Prius
    16,159
    I believe that part is plastic so you can touch it up but I mean once you dent plastic, it's hard to repair it unless you take it to the body shop to fill up the cavity and sand out the ridges.
  13. EyePrime
    268
    115
    2018 Prius Prime
    Ok, thanks very much. I don't think its a dent. More like a deep scratch in the paint
  14. Tideland Prius
    16,159
    If it's just paint, then hopefully a touch-up will help. It has both a paint and a clearcoat side on the pen. It won't be pretty though as my success rate in hiding a scratch is pretty low lol. I usually just do chips since I have a higher success rate of hiding them (it looks ugly with just the paint but it's better hidden once you apply the clearcoat).
    On the plus side, plastic won't rust.
  15. hill
    8,192
    It's right on a crease, so that'd be a major no-go .... especially because it's aluminum, which is very resilient at keeping its existing shape. YouTube videos of aluminum rework show this as an area that will definately require paint rework - as well as removal of a bunch of parts to get at the back side of the metal.
    that sky blue light is the charge port. BAM !!!
    It takes a bit of directed light & just the right angle to notice it .... but being the only flaw (not even front end rock chips .... yet) in the paint/body - and chest / stomach height? oh yea, we notice. Baaah ... it sorta helps remind us to have humility.
