Screen Brightness and Contrast
Discussion in 'Prius c Main Forum' started by jerryd, Jun 8, 2012.
  1. jerryd
    jerryd Junior Member
    51
    Florida USA
    Prius forum,
    I think there was thread on this issue but I couldn't find it.
    I have a Prius C II and have experienced the glare problem on
    the Nav screen. I tried to adjust the contrast and brightness
    but it didn't help. Has anyone found a solution for this?
    Jerryd
  2. moezer2112
    moezer2112 Futurist
    115
    50
    Iowa
    Dark tint on the rear passenger window helps if you're interested in that approach. You can try it by covering the rear passenger window with a dark towel and sitting in the drivers seat and looking at the screen again.
  3. akh02
    akh02 New Member
    63
    Oregon
    Turning the brightness all the way up and the contrast all the way down helped significantly.
  4. SquallLHeart
    SquallLHeart The Techie Guy
    826
    247
    San Jose, CA
    a C II with a Nav?
  5. Iconn127
    Iconn127 Master Diagnostic Technician
    44
    Cameron Park, CA
    multi info screen?
  6. Iconn127
    44
    Cameron Park, CA
    nvm, his info on left says three
  7. jerryd
    51
    Florida USA
    Prius forum,
    Thanks for the replies.
    It is a III my bad.
    I did turn the brightness all the way but it didn't seem to help much.
    jerryd
  8. akh02
    akh02 New Member
    63
    Oregon
    Turning the contrast down is what made the difference on mine. Counterintuitive, but it worked.
  9. BGGirl
    BGGirl Member
    480
    84
    Kentucky
    I am getting my windows tinted in the next couple of days.. I am hoping that will help with mine. :)
  10. Iconn127
    44
    Cameron Park, CA
    i get a sweet glare across just about everything of mine, soon to have 5% rear 40% front
  11. MGSF
    MGSF Junior Member
    SF
    also, for those who turn on their headlights during daytime, adjust for that as well (brightness up, contrast down). couldn't see the screen at all before adjusting
  12. Iconn127
    44
    Cameron Park, CA
    you can also adjust to keep it bright at all time with the dimmer sw just left of the steering wheel.
