Screen protector?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by jtowndog, Apr 12, 2005.
  1. jtowndog
    jtowndog New Member
    49
    Lomita, CA
  2. jtowndog
    jtowndog New Member
    49
    Lomita, CA
    The response from the seller:
    These screens are specifically designed to protect and reduce glare, it made out of a special micro thin P.E.T with silicon coated, which means it won't leave residue or damage your screen. It does not interfere with the touch screen technologies. It's being made under extensive research and development, cut from precision cutter using data from the manufacturer. Basically just peel and apply.
    www.lcdprotector.com
  3. Areometer
    Areometer Silver Business Sponsor
    578
    Tyngsboro, MA
    have you received & installed yours? How do you like it?
    Thanks.
  4. Godiva
    Godiva AmeriKan Citizen
    10,339
    I have it and installed it.
    I used the same screen cleaner I use on my laptop to clean screen first. I didn't get it straight the first few times so peeled off and tried again. I used the squeegee I got from Dale with his decals to smooth the film. Touchscreen works fine. No adhesive to muck up the screen.
  5. bshef
    bshef Active Member
    510
    76
    OC So. Calif.
    I purchased and installed mine just this past week....... fits very nicely and the install was very easy.
    The plastic is very very thin (not a negative), so the touch response is not affected.
    The only advantage I see about this product is ........now my screen (in my mind) seems less likely to be scratched/damaged.
    Their product is expensive at $16 (that's shipping included).
    I emailed them about a possible group purchase but did not receive any replies!
  6. catsbox
    catsbox Member
    295
    Bellevue, WA
    I purchased mine from EBay
    [web:83d93e6c70]http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&category=38653&item=7973312396&rd=1[/web:83d93e6c70]
    Price: $11.95
    Plastic is thick enough to protect but thin enough to still be able to operate the touch screen. Fits perfectly, very easy to install. Have not tested it in the direct sun yet but it does seem to reduce the glare. The seller shipped promptly and was otherwise good to deal with.
  7. Areometer
    578
    Tyngsboro, MA
    I got & installed their screen protector on my Prius & my PocketPC Phone.
    Goods: It feels thicker than other films that I have used before. This translates to easier positioning/installing. But I still managed to trap in 2 bubbles. Also, tactile feeling is better than before. Screen seems to be more responsive to my touch than before, which is unexpected. Glare is cut down even more now. Nice.
    Bads: I wear polarized sunglasses a lot, gee, sunglasses + this screen protector = illegible & darkness. Now, I can barely see my screen unless I move my head to the right & stare at the screen straight ahead.
    But it's still a keeper for me for now.
