Screen shuts down constantly.
Discussion in 'Prime Audio, Electronics, and Infotainment' started by trbump, Dec 31, 2016.
  1. trbump
    trbump Junior Member
    2013 Prius Plug-in
    I just bought the advanced last week and my screen shuts down when it's on FM constantly. It also happened on the one I test drove. It sounds like it's a common problem as the dealer informed me that they had others with the same issue. Has anyone heard if there's a fix for this?
    49,694
    a problem with the new prime? i can't believe it. i recall some 2016's resetting or something, but i figured everything would be fixed for 2017.
  3. Civic4982
    Civic4982 Member
    46
    40
    I had a similar problem on mine.
    The problem with mine was a bad USB cable as I had my phone connected.
    The frequent disconnects and reconnects made the computer on he display unhappy and it was really on the fritz.
    Replaced with a new apple brand cable for my iPhone and problems resolved.
    iPhone ?
  4. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    I had exactly the same problem with my 3 day old Advanced. Civic4982's post solved my problem. Everything was working until I switched to a 14" black Satechi "MFI_Certified" lightning cable I had bought from Amazon. I didn't like a white Apple cable routed into the armrest compartment for the way it stood out against the black interior and also the 3 ft. length. I saw Civic's post and switched back to an Apple cable and all the problems vanished.
    Civic4982 likes this.
  5. trbump
    2013 Prius Plug-in
    Thanks for the replies, however, this is the screen itself turning off on fm, not my iPhone. Everything else seems to work fine.
  6. Will_Prius16
    Will_Prius16 Member
    127
    64
    Now in West Covina, CA
    Do you have a phone plugged into the USB port?
  7. trbump
    2013 Prius Plug-in
    No, I have yet to plug it in. I've only used Bluetooth so far.
  8. Civic4982
    Civic4982 Member
    46
    40
    Interesting. Your problem appears to be different than mine.
    Yes mine was the 11.6" screen shutting off but my phone was plugged into USB.
    If you're not plugged in then our issues are notably different.
    iPhone ?
  9. Jon Wilson
    Jon Wilson New Member
    Portland, OR
    Have Prime Advanced (11.6" screen) with rebooting issues. Started last week when on FM and I selected HD radio subchannel. The unit rebooted, acquired the radio signal, then reboots. No other FM channels can be selected. The cycle continues until audio is either turned off or another source is selected.
    After taking it to the dealership, they said it was a bad display unit. I just had my display unit replaced today. On the drive home, I selected an HD subchannel and the reboots started again.
    Definitely not a hardware issue. This appears to be an Entune/firmware glitch. Will be taking back to dealership...
