Screen Trip Meter not Resetting
Discussion in 'Gen 2 Prius Main Forum' started by penpendisarapen, Feb 25, 2004.
  1. penpendisarapen
    penpendisarapen New Member
    51
    Pacifica, CA
    This is the third time I've gassed up, and the screen odometer reading and MPG average did not automatically reset. The numbers stayed the same even after I reset the actual odometer to zero. What happened?
  2. Bob Allen
    Bob Allen Captainbaba
    1,273
    Seattle, WA
    My guess is that the chronosynclastic mass fluctuometer failed, but I might be wrong. Haven't picked up my Prius yet so I'm not yet into these problems and questions; hope to be soon.
    B
  3. penpendisarapen
    51
    Pacifica, CA
    Yeah, that's the one next to the thingamawhatzisdodaad.
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You said a couple things that're throwing me off....
    You don't need to reset the odometer or anything else after refueling. Just get in and drive away from the pump. Anywhere from 10 feet to 150 yards (give or take) away from the pump the mileage and MPG should automatically reset (on the MFD). Pushing the ODO/TRIP buttons will only reset the Trip setting on the HUD by the speedometer.
    You CAN manually reset the MPG and refill mileage thing by pushing the RESET button on the MFD touch screen, but you should not need to do that.
  5. wesj49
    wesj49 Junior Member
    72
    CA Central Coast
    I have discovered that if I leave the car ig-on, by the time I have finished filling the tank, the guage is showing full and the consumption numbers reset almost as soon as the car moves.
  6. Frank Hudon
    Frank Hudon Senior Member
    4,147
    if you push the Reset on the MFD does it change or not? if it does do you want to swap the computers in your car with one that does automatically reset??
  7. penpendisarapen
    51
    Pacifica, CA
    I drive about 20 feet to air pump station, and wait for the fuel gauge bars to reach full, but the screen odometer stays the same. I have to hit the RESET on the screen each time after my fill up. It used to just reset it as soon as I start the car after the fill up.
  8. efusco
    19,891
    1,192
    Nixa, MO
    Just keep driving, 20 feet isn't usually enough. Just drive down the road. I'd say if you hit 1/2 mile and it hasn't reset then do it manually and I'll admit there's something wrong. In my experience it sometimes resets almost immediately, other times I'll pull out from the pump, go to a stop sign, turn right, go to a stop light, then pull onto the main drag--probably 100-150 yards total distance before it finally resets itself. But it's never failed to reset itself within 1/4 mile.
    --evan
  9. sparkymarvin
    sparkymarvin Member
    144
    At the airport.
    I would love to have my MPG/mileage on the multi-function display not reset. It would be like driving a classic Prius and I bet I could get my average MPG reading higher and higher this way.
    I'll be interested to see how this all turns out for you penpendisarapen. Keep us updated.
    ~Andrew
  10. penpendisarapen
    51
    Pacifica, CA
    I manually reset it to track my mileage per fill up. I guess I'll wait a little bit longer next time.
  11. rflagg
    rflagg Member
    947
    Springfield, VA
    May sound like a stupid question, but since I don't have mine yet, I thought I'd ask - is it 'safe' to leave the car in this mode while fueling? What modes are safe for fueling, or should it be completely off? Anyone?
    -m.
  12. sparkymarvin
    sparkymarvin Member
    144
    At the airport.
    rflagg,
    Toyota recoments (and I strongly agree) that you turn the "hybrid system" off when fueling.
    Some would say it is okay to leave the car on, but paranoid people like me would never do this. If you talke to mechanics too, they will tell you that you can trip codes or get a check engine light if the fuel cap is off when the internal combustion engine is running.
    ~Andrew
  13. wesj49
    72
    CA Central Coast
    Yeah, when the engine is running, but the engine doesn't run when I do this. I have a notion that the same behavior will occur if I leave the ACC on but I have not tested that yet. What I have noticed is that the reset does not occur until the guage replenishes all the blocks and that seems to be a slow process and you could be driving some distance before that happens.
