Screw in tire and TPMS
Discussion in 'Gen 3 Prius Technical Discussion' started by Heat Gun, Jun 3, 2014.
  1. Heat Gun
    Heat Gun Junior Member
    56
    Los Angeles, California
    Hi all, I have 2014 prius and I realized a screw in rear right tire, no leaking, psi at 37, wen to firestone to have it fixed and I was told it is $20 to repair + $10 for TPMS, (tpms light is off)
    Why do I need TPMS? or Do I need it? I made an appoinment but haven't showed up yet, should I agree on paying for TPMS or just be bitchy ? :)
    Thanks
  2. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    Got an America's/Discount Tire near you? The America's Tire near me fixes flats for free....
    SCH-R530M ?
  3. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    Nothing needs to be done to the TPMS......just get the wheel balanced after the repair since they remove a small amount of tire on the inside before the put the patch on.
    Heat Gun likes this.
  4. Heat Gun
    56
    All four tires have warranty from America's Tire but I dont have any within 10 miles, Firestore is down the street, pepboys 1/2 miles away
  5. Heat Gun
    56
    Thank you, I will just go to Pep Boys then, they dont charge for TPMS
  6. Heat Gun
    56
    Update:
    Went to Pep Boys and got it repaired for $10
    sfv41901 likes this.
  7. jzchen
    jzchen Newbie!
    3,298
    1,009
    Arcadia, CA
    I'm not 100% sure about ones far away, but here, they offer free repair to any tire, purchased from anywhere. I think it's their way of promoting themselves/getting new customers. They also price match any competitor pricing. (Their store is always busy.)
    That said, $10 is not bad, not bad at all....
  8. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    You could have plugged it yourself. Walmart sells kits for a few bucks.
    Otherwise, if you're not inclined, I think $10 is a very reasonable price to have someone else fix it.
    xliderider likes this.
  9. Okinawa
    Okinawa Senior Member
    1,333
    317
    I would go to Discount Tire or someone else. Nothing needs to be done to TPMS.
  10. fuzzy1
    10,163
    So far, I've had one flat repair with TPMS, not on the Prius. Walmart fixed it for $10, no surcharge for TPMS. Normally I wouldn't go there, but we were traveling and it happened too late to reach the regular tire shops before closing time of 6 pm. But a Walmart tire shop was open until 7 pm. A Costco tire shop was open even later (8 or 8:30), but would fix only their own tires.
  11. er86
    er86 Junior Member
    42
    Austin, TX USA
    I noticed a low tire so I topped off the pressure and stopped by a Pep Boys on the way to work. I stepped inside and enjoyed the A/C, television and WiFi while the gentleman looked at my tire. They removed the nail and repaired the tire at no charge, which was a GREAT surprise to me!
  12. priusdonkey
    priusdonkey Member
    211
    51
    You have to be careful when removing and installing the TPMS, they are expensive and easy to damage.
  13. spiff72
    spiff72 Member
    184
    37
    West Michigan
    Jut curious - when they repair a tire with a plug, don't they leave it mounted to the rim? I swear I saw them do it once on a previous car, and they may have deflated the tire, but I didn't think it needed to be taken off the rim...
  14. KennyGS
    1,243
    1,044
    Keystone State
  15. fuzzy1
    10,163
    Do any legitimate tire shops do this?
    I thought plugs were just for DIY fixes.
  16. KennyGS
    1,243
    1,044
    Keystone State
  17. priusdonkey
    priusdonkey Member
    211
    51
    costco does. you plug the hole and patch the inside of the tire.
  18. Okinawa
    1,333
    317
    Putting a plug in a tire the old way was leaving it inflated and on the car. The new way and the different type of plug requires taking the tire off the car. The service manager at a Firestone garage took me through the entire procedure and explained it to me. He was a very patient and nice guy to do that I thought.
  19. Fore
    Fore Don't look back!
    494
    107
    This way is not recommended anymore and dangerous!
  20. sfv41901
    sfv41901 Masta S
    4,591
    5,292
    Palmdale, Ca
    That's the classic "u must be a red neck if u plug ur tire like this!"
    VS980 4G ?
