Sea Foam
Discussion in 'Gen 2 Prius Main Forum' started by Utah Cam, Jan 23, 2021.
  1. Utah Cam
    Utah Cam New Member
    Utah
    I’m checking in with the group to see if anyone recently has tried the Sea Foam injection cleaner into the cylinders by way of spark plug hole to break up deposits that cause oil consumption trick. I seem to remember someone awhile ago said to do this and let sit overnight. It’s supposed to get the deposits off the rings and have them seal better. I’ve got a 2007 with 215,500 miles and I add at least a quart of oil every thousand miles. Any help is appreciated.
  2. PriusCamper
    PriusCamper Senior Member
    11,105
    4,520
    Pacific Northwest, USA
    There's plenty of "piston soak" recipes out there. If I were you I'd put some time into reading about as many different recipes as are out there and then decide what suits you.
    And in terms of the effectiveness of different products, I recently found this dude on YouTube who is DIY product testers for products like that: Project Farm - YouTube
    SeaFoam ranks pretty high in most of his tests...
    Utah Cam likes this.
  3. qmanqman
    qmanqman Active Member
    309
    112
    CO
    I did it with my Accord. It helped but didn't solve it. The oil consumption went down for sure. But don't use seafoam. Use carb cleaner. Nothing cuts carbon deposits better than carb cleaner. Just make sure to do it correctly. And make sure to change your oil right afterward.
    Skibob and Kaptainkid1 like this.
