Seafoam, I'm a bozo, now Prius won't start
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gsxranger, Feb 1, 2017.
  1. gsxranger
    gsxranger Junior Member
    Missoula
    I have a 2007 Prius that started using a lot of oil, 2 qts/ 5k. It snuck up on me and got really low a couple of times, so I decided to address it with the "seafoam soak" in the cylinders. I put 1.5 OZ in to each cylinder, figuring if it leaked down that was the recommended amount to add to the crankcase anyway. I soaked it for 4 days, and rotated the engine with a box wrench pushing toward the cabin from the top of the motor. I tried to suck the fluid back out of the cylinders but they seemed dry. Well I put everything back together and went to fire it up. Now it starts, shudders, runs sort of smoothly and then shuts itself down, and gives the !problem car error, and triangle error in the course of about 5 seconds. Power off, start it and it does it again. Any ideas?
    Thanks
    Jim
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Only takes one real low oil event to at least damage the oil scavenge ring on the bottom of the piston and then it really starts to eat oil and if really low damages the lower bearings. Usually from what we see if takes out the piston wrist bearing. It will start knocking soon.
    And then if kept driving usually blows the #3 piston out the side of the block.
    Seeing alot of these low oil deals. As your car gets older it needs more attention just like a human. Instead it gets less.
    Toughest little motor ever. Cannot tolerate no oil pressure.
    I don't care what car you own check the oil first thing every saturday morning before you start the car. Keep the oil at the full line always. Car engines use splash lubrication to oil the bottom of the motor. No splash no lubrication.
    Prius_Angie, maleko and windstrings like this.
  3. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    Your gas engine never actually started. What you felt was the motor generator spinning the ICE at operating RPM speeds. Check all your connections to your coil packs. Maybe unplug them all and reconnect them.
    goldfinger likes this.
  4. gsxranger
    Missoula
    Ok will do! It all went together smoothly, and all of them are "clicked" in and the spark plug covers are screwed down. Will it reset anything if I disconnect the positive battery terminal? Any concerns if I may have rotated the motor backwards?
  5. gsxranger
    Missoula
    Hey thanks Aaron, that was it, #1 wasn't clicked all the way in. It starts and runs fine now. Now how do I get rid of those dash warning lights!~?
    Aaron Vitolins likes this.
  6. CooCooCaChoo
    CooCooCaChoo Senior Member
    953
    533
    Cow-lee-fornia
    2023 Prius
    Disconnect the battery for 1 minute and reconnect should clear. Or if you have a scanner that should be able to clear codes as well.
    windstrings likes this.
  7. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    ^ the negative terminal.
  8. dolj
    dolj Senior Member
    8,217
    4,187
    Wellington, New Zealand
    ^ It doesn't really matter which one. It just so happens that the Prius can be disconnected at the positive quite easily without tools.
    edthefox5 and m.wynn like this.
  9. audiodave
    audiodave Active Member
    798
    269
    US
    Like to know how the engine and milage have been after some miles. Get back to us.
  10. fotomoto
    fotomoto Senior Member
    5,629
    3,802
    So. Texas
    If the issue is resolved, the trouble light will cancel itself after a few (I think 5) trouble free on/off cycles.
  11. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Never done it that way but have poured it down the throttle body which the car absolutely hates if you put it in diagnostic mode or the engine stays on it will stay on longer hopefully burning way all the cleaner I had to do it twice with squirting it in the throttle body with air codes but after it burns and you drive a little bit both error codes cleared by themselves after each stop at a reset
    Prius_Angie likes this.
  12. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    It you disconnect the negative for 10 minutes will clear the memory completely of the last 6 months put gas mileage sucks the first 50 miles then learn the way you drive also if you have the gas tank full it calibrates the fuel tank
  13. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    I use seafoam in the oil before oil changes a few days and seafoam in the gas mixed with Lucas or Marvel Mystery Oil combination seems to work much better than just one and you can use a lot less 2oz each 5mpg boost
    Prius_Angie and Aaron Vitolins like this.
  14. audiodave
    798
    269
    US
    Marvel mystery oil in your gas? Lucas the injector cleaner?
  15. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    Both in gas Marvel Mystery Oil does both Lucas Fuel Injector Cleaner
  16. Mendel Leisk
    40,584
    Could be something to that. I disconnected the negative cable a day back, just for safety while I wired in a battery charger quick connect. The next day when I started the car it seemed a little "off". One thing, about one minute after start up, revs went way up, for about 10 seconds, then settled back down. Also, first start up, when (I thought) I'd shifted to reverse, it somehow ended up in Neutral, and warned about something, maybe shift to Park?? I shut down and restarted, all was fine the second time.
  17. drew935
    drew935 Member
    168
    23
    Nor Cal
    I may try this next time for the oil change.
  18. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
    So it working or not
  19. Mendel Leisk
    40,584
    Yeah it got back to normal, but I really got the sense it was reinitializing some stuff.
  20. Jmack111
    Jmack111 Member
    371
    78
    Tacoma wa
