Sears $25 DieHard 750W Power Inverter
Discussion in 'Gen 3 Prius Accessories and Modifications' started by pmike, Oct 27, 2014.
  1. pmike
    pmike Member
    237
    81
    Central Florida
  2. JC91006
    16,673
    8,518
    Buy this if you have $25 to burn. You will want to upgrade and get the full capacity your car can deliver (from 12v)
  3. pmike
    pmike Member
    237
    81
    Central Florida
    What do you recommend?
  4. JC91006
    16,673
    8,518
    You can buy something that's closer to 1000w. They range from $65 - $500
  5. Easy Rider 2
    Easy Rider 2 Senior Member
    1,584
    258
    Ocala, FL
    OK, I'll bite...............
    IF your requirements never exceed 500W or so, why should you spend the extra money ??
  6. JC91006
    16,673
    8,518
    Because you never know when you need to exceed that wattage and wished you would've just bought the bigger one to begin with. Like you suddenly discovered camping and want to bring a mini fridge and a TV with you but the 750w just isn't enough.
  7. pmike
    pmike Member
    237
    81
    Central Florida
    I would rather stay away from the 12v limit, this will meet my needs and at the
    That is called a hotel. Almost as funny as seeing someone running a window a/c in a tent.
    If this can run my fridge, that is the only thing that matters. I have a 3000/3500 generator on standby too.
    I will eventually get a AIMS inverter that runs off the hybrid battery but cannot justify it at the moment.
  8. JC91006
    16,673
    8,518
    Not everyone has a generator on standby. But if you can take the noise of the generator, I guess you don't need more power than what the 750w will give you.
    I don't have a generator so I got the 1000w just in case I need to run my fridge and give myself some lighting during a power outage.
  9. pmike
    pmike Member
    237
    81
    Central Florida
    They cancelled my order due to no stock at the most local store. Guess I'll have to hold out for an AIMS.
  10. Obernelson
    Obernelson Junior Member
    Massachusetts
    I opted for a 400 watt pure sine wave as I have had burned out some sensitive electronics on the square wave. I have a 900 watt "modified sign wave" to use when I need to run my power equipment. 400 watts gives me the power I need for those things that I run that are sensitive and I now don't burn power supplies out at additional costs
    iPad ?
