Seat Belt Chime is annoying
Discussion in 'Gen 2 Prius Accessories & Modifications' started by adamorzol, Apr 18, 2007.
  1. adamorzol
    adamorzol New Member
    65
    Does anyone know how to get rid of the annoying seat belt chime? I wear my seatbelt 99 percent of the time but there are times when I am on a residential joy ride that I don't want use my seat belt.
    Are there some "hack" instructions available from anyone on how to stop the chime from seatbelts for both the driver and passenger?
    Thank you Gurus!
  2. NoMoShocks
    NoMoShocks Electrical Engineer
    1,292
    82
    Camas, WA
    Search for the Back Up Chime Hack. For 2007, I am pretty sure is kills all interior chimes.
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    82
    You have to kill each beep separately.
    Turning off BEEPS
    1. Power on the car to IG-ON or READY. IG-ON will do for this purpose.
    2. Using the Trip/ODO button, set the Trip/ODO display to ODO - not Trip A or Trip B
    3. Power off the car.
    4. Now power the car to READY (brake on). This is required so that step 6 works correctly.
    5. Immediately, within 6 seconds of powering on, press and hold the Trip/ODO button for 20 seconds or more. Do not release, just hold it for 20 seconds, then
    6. WHILE STILL HOLDING ODO button, shift the "gear" selector from P to R, then back to P. Now release the Trip/ODO button.
    7. If the last step was successful, "b on" or "b off" should be displayed in the location where the Trip Odometer or Odometer is normally displayed. "b on" is beep on, and "b off" is beep off.
    8. Press Trip/ODO to toggle the mode to the one you want.
    9. Now power the car off to exit the toggle mode.
    10. Power the car on to READY and confirm the reverse beep status by shifting to R. The beep should not be audible if "b off" was selected, and should be audible if "b on" was selected.
    The above procedure turns off the back up beep. To turn off the driver seat-belt beep, instead of shifting in step 6, latch your seat-belt. This takes some contortions since you have to do it with your left hand since your right hand is still holding the ODO button. I prepared by pulling the seat-belt out all the way and holding the strap in my teeth so there would be no tension. To turn off the passenger seat-belt beep, at step 6 have the passenger sitting in the passenger seat latch that seat-belt buckle.
    I found all this at http://priuschat.com/index.php?showtopic=24769
    fishnlady likes this.
  4. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I'd much rather be picking windshield glass out of my face than listening to that annoying beep too. Dude, buckle up. The beep won't hurt you, but bouncing off things inside the car will.
  5. kiwiruss
    kiwiruss New Member
    29
    The backup hack worked for me. took me two tries to get it though
  6. SiliconAddict
    SiliconAddict New Member
    44
    <div class='quotetop'>QUOTE(subarutoo @ Apr 18 2007, 02:24 PM) [snapback]425514[/snapback]</div>
    the only problem is when you have enough weight on the passenger seat to set off the alarm. <_<
  7. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Wearing a windshield; now THAT'S uncomfortable!
    In all honestly, I've disabled both seatbelt chimes and that terribly annoying "the car is in reverse" beeper, too. But, really, it'll be that one time when you don't buckle up that you get in an accident, or so it seems.
  8. Dave
    Dave New Member
    340
    Santa Cruz, CA
    <div class='quotetop'>QUOTE(SiliconAddict @ Apr 18 2007, 04:33 PM) [snapback]425654[/snapback]</div>
    Interesting. I drive a 2004, and the alarm does not go off when I have freight weight in the passenger seat. The seat belt light comes on on the dash, but no alarm. As for disabling the alarm, I won't. I don't go anywhere without buckling up, and if you ride in my car, you buckle up as well, or walk.
  9. SiliconAddict
    44
    <div class='quotetop'>QUOTE(Dave @ Apr 18 2007, 08:25 PM) [snapback]425712[/snapback]</div>
    *shrugs* I do. I've put two grocery bags on it and had the thing beeping at me to buckle up. Ditto with putting my laptop bag and tool bag on the seat as well. Sure it stops after a while but the light still flashes on the dash. Toyota should have put a sensor on the back of the seat as well to see pressure in both spots. :mellow:
  10. subarutoo
    1,213
    23
    Chatsworth, CA
    <div class='quotetop'>QUOTE(SiliconAddict @ Apr 20 2007, 07:22 AM) [snapback]426681[/snapback]</div>
    Just throw your stuff in the back seat. What's the problem?
  11. SiliconAddict
    44
    <div class='quotetop'>QUOTE(subarutoo @ Apr 20 2007, 02:23 PM) [snapback]426919[/snapback]</div>
    Well other then the fact that the back seat is folded down to hold all the boxes that contain the parts for my job, which is routinely filled all the way up. Maybe because when I get out of the car I would rather just grab my stuff and go instead of getting out of the car, opening up the back. Grab my stuff. Go back to the front door, lock the car, and go. That's assuming I'm also not shoehorned into a parking spot which is even more fun. Am I being lazy? I don't think so. I just don't think I should need to treat the prius any different then any of the other cars I've owned in the past. Back seat is a work around, not a solution. Also I work out of my car.
    I'm finding more and more of these quirks on this car. Nothing that really kills the experience. Just more a.. <_<
  12. RobertG
    RobertG New Member
    166
    Northern California
    <div class='quotetop'>QUOTE(Pinto Girl @ Apr 18 2007, 04:36 PM) [snapback]425658[/snapback]</div>
    One of my brothers imagines the sound of such an alarm as the voice of a doctor saying that he will look a lot better if he doesn't go through the windshield.
    A friend was in a relatively minor accident. She didn't have her seatbelt on and had to have surgery for a cut on her forehead.
    My wife was nearly in an accident years ago. A road narrows to one lane in each direction. Some inebriated college students didn't notice that and hit a woman nearly head-on. That woman commented wearing her seatbelt saved her from any injury. I think that accident was probably settled out of court. The inebriated driver came up to that woman and said, "Did you see what happened? I sure as heck didn't." Later, when the police put him in their car, he was asking his friend to join him, thinking he was getting a ride home from the police.
    I have yet to disable the chime for seatbelts, and don't plan to. I usually have it on before starting the car.
  13. Bill Merchant
    4,096
    82
    I live out in the country, with a long driveway. There are no side streets and no traffic. I stop at my mailbox and undo my seatbelt to get the mail. I don't put my seatbelt back on to drive on my own driveway. I turned off the seatbelt beeps a long time ago. I ALWAYS wear my seatbelt on the public road. I latch it before starting the car.
    To each his own. Just don't be sanctimonious.
  14. box
    box New Member
    Haha, I just had to reply.
    I'm the exact same way. If your belt isn't on, you aren't in my car.
  15. hb06
    hb06 Member
    550
    Huntington Beach, CA
    <div class='quotetop'>QUOTE(box @ Jul 29 2007, 08:01 AM) [snapback]487059[/snapback]</div>
    If you are gliding at 12 mph or under, there is no seatbelt beep. Not exactly for cruising speed but at least you can glide into a parking spot belt unhindered.
  16. aaf709
    3,862
    2022 Prius Prime
    We buckle up before the Prius is powered up, so we never hear the alarm.
  17. rsvogt
    rsvogt New Member
    Step One: Buckle up
    Step Two: Put Foot on Break
    Step Three: Push power button
    What seatbelt chime?????
  18. patsparks
    10,664
    567
    Adelaide South Australia
    Yeah, I find mine doesn't chime if fasten my seatbelt.
    You should always wear a seatbelt, makes it easier to find the body.
  19. Sonny Jim
    Sonny Jim New Member
    260
    Newport Beach, CA
    <div class='quotetop'>QUOTE(Bill Merchant @ Apr 17 2007, 10:53 PM) [snapback]425161[/snapback]</div>
    On my 2005, this was correct; on my new 2007, when I disabled the reverse beep, it disabled the seatbelt chimes as well.
    I always wear my seatbelt, but I don't need a chime to remind me, just as I don't need a beep to tell me that I'm in reverse :p
  20. priussoris
    priussoris New Member
    1,005
    we bought our prius with 1 mile on it and the drivers side seat belt beep never has worked, but the passenger side beeps when the dog sits there, or a bag of groceries.
    So how do you turn it on if it was never turned off?
