Seat bolt torque?
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by climateguy, Feb 28, 2015.
  1. climateguy
    climateguy Junior Member
    65
    Santa Fe, NM
    Does anyone know the torque specifications for the seat hold down bolts (front and rear) for a 2012 v?
    Thanks!
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    It would be in the TIS documents.
    Don't do as many do: Torque it until the threads strip, then back it off a quarter turn...
    climateguy likes this.
  3. Mike500
    Mike500 Senior Member
    2,593
    764
    I believe that they are JIS M10mmx1.25. For them, it would be 38 ft. lbs.
    #3 Mike500, Feb 28, 2015
  4. RRxing
    RRxing Senior Member
    2,520
    1,791
    NEPA
    Not sure about the 2012 v, but the 2010 specs are 27 ft-lbs, all bolts, front and rear.
  5. climateguy
    65
    Santa Fe, NM
    Thanks for the answers and the suggestion regarding TIS. I looked at the TIS document and indeed, the torque is the same for the 2012 v as for the 2010 as listed by RRxing...27 ft-lbs for all the hold down bolts, front and rear.
  6. Mike500
    2,593
    764
    Since the bolts are 10.9 J.I.S. grade, they will effectively take 38 ft. lbs., although Toyota specifies 27. Either way is fine.
