Seat heaters
Discussion in 'Gen 3 Prius Main Forum' started by sktn77a, Jan 22, 2011.
  1. sktn77a
    sktn77a Member
    294
    NC
    Hi there: I have a 2010 Prius 4. The heated seats are real hot when first swiched on. After about 3-4 min the passenger seat appears to either switch down to a low setting or switch itself off (can't really tell if it's on a low setting or if its off completely). The light on the switch remains on. Is this normal operation or is there a problem?
    I've seen other threads on this but nobody actually states "This is normal - this is how they are supposed to work".
  2. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    It cycles and it's supposed to be normal.
  3. sktn77a
    sktn77a Member
    294
    NC
    Thanks 32k. Makes sense. My seat heater is so hot when its on that I thought it might be overheating and shutting itself off.
  4. Gumbylives
    Gumbylives New Member
    Arizona
    The heated seats warm up and then cool down (cycle). You'll also notice that the back of the seat warms up. I've never seen any correlation between the car heater temp and the seat heaters. The owners manual only tells you how to trn on the heaters and doesn't say anything else.
  5. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    The "thermostat" within the seats is preset and not adjustable. That said, I rarely find them to be too hot.
  6. Texas911
    Texas911 Member
    405
    Houston, Texas USA
    I just wish that the buttons were easier to get to and more intuitive to use. I mean a button located on the left and right instead of up and down.
  7. Barefoot
    Barefoot Junior Member
    43
    Lusby MD
    I like the thumbwheel in my '06 Sienna much better. I can set it where I want it.
    For me, the seat heater in the Prius is either too hot or off.
  8. Lottamoxie
    Lottamoxie Member
    403
    28
    Southeast US
    I've used my Prius butt warmer a few times. I generally use it for no more than 2 or 3 minutes because it gets quite warm and I don't need toasted buns. By then I'm sufficiently warm enough to forgo additional cooking time.
  9. duffasaurus
    duffasaurus Senior Member
    177
    38
    Charlotte, NC
    Luv my heated seats, takes the edge off until the heat kicks in. Yes, the switches should be positioned right & left and turn off when the vehicle is shut down!
  10. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    Agree 100%
