Seatbelt and Back up beepers
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Conrad, Apr 20, 2012.
  1. Conrad
    Conrad Junior Member
    23
    Santa Clarita, CA
    Is there some slick way to turn off those Beepers on my PIP as I could on my 2005 Prius.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    You have to goto the dealership and they can turn things off, they are listed in the manual which can be changed. You can't do it yourself like on the Gen II.
    Some on here who ave a Scanguage can turn it off themselves using it. There are threads describing the process, I'm not aware of how to do it since I don't use a scanguage.
  3. Conrad
    23
    Santa Clarita, CA
    Thanks, I suspected that and I'm probably not computer savy enouhj to use a scangage.
  4. CharlesH
    2,785
    1,152
    Roseville, CA
    The dealer I bought the car from changed (without charge) the backup racket to a single beep. Is the seatbelt alert listed as a customization? I am not sure if the dealer is allowed to turn it off (some kind of liability thing).
  5. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    This is what I was told. Essentially, that it was absolutely, positively against Toyota's policy to disable the seat belt beeping. But it IS listed as a customizable feature.
  6. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    Yes the seat belt alert is an option. The dealer or anyone with an OBD II tool can turn it off. The option codes are the same as in the gen III. It's a 5 minute operation.
  7. LenP
    LenP Member
    257
    69
    Morris County, NJ
    I had the reverse beep changed to 1 beep, Pure bliss. :) It was fast and free at my dealer. I believe the same can be done with the seat belt. You can't turn them off, but can have them changed to one beep.
  8. bfd
    bfd Plug-In Perpetuator
    659
    172
    Close to SDSU in the Far Southwest Corner of Cali
    Because I forgot to ask about this last night, I'll be attempting this tomorrow with a ScanguageII and the codes from another thread for the two functions.
    Still, looks pretty straightforward since the TXD and RXF codes are already in place.
  9. AND, THE RESULTS ??
  10. bfd
    659
    172
    Gold.
    Yes, it works. Probably not easy for anyone who hasn't dealt with inputting codes from a device like the ScanGaugeII, however. If I hadn't already had a ScanGaugeII, I would've just taken the PIP in and asked them do the code reversal at a service. Some service depts won't do it for "free", so ask them do it as part of the write up for the first 5K service. If they balk, you walk.
    There's no safety issue for them to hide behind. These are all customizable features. Search through the forum and you'll find plenty of threads on this…
    Andyprius # 1 likes this.
  11. Is there a procedure posted for the PIP on Priuschat?
  12. bfd
    659
    172
  13. Justin Bird
    Justin Bird Junior Member
    Auckland, New Zealand
    I managed to turn off the seatbelt beeps by in my 2012 PIP by disconnecting the seatbelt sensor connector under the seat. It's the little white one to the side of the big green one underneath the seat. No codes triggered, no warning lights on the dash, just beautiful silence :D
  14. Pluggo
    Pluggo Senior Member
    608
    532
    Folsom, Pennsylvania
    You might have also disconnected the airbag. At least in the passenger seat, no passenger = no airbag deployment.
  15. QuantumFireball
    QuantumFireball Active Member
    419
    269
    Ireland
    There's no "might" about it, the passenger airbag (and probably seatbelt pre-tensioner) will not work with the seat sensor disconnected.
    If you're putting objects on the seat that are heavy enough to trigger the seatbelt warning, you probably should secure them with the seatbelt...
