Second day with my Prius
Discussion in 'Gen 2 Prius Main Forum' started by yoyoman, Jul 16, 2005.
  1. yoyoman
    yoyoman Active Member
    342
    117
    San Jose California
    I found out that my oil level in my brand new prius is above the high level. Is this normal or I have to drail it until the oil is below the high level?
    Today, I drove my Prius form Albuquerque NM to Santa Fe round trip for fun. I'm getting about 40MPG but the battery is almost drailed out? Only the last 2 battery level left on the display when I got home. I was using the cruise control at 70-75MPH. The mileage of my car is only 150miles.
    I hope this is all normal ? Or I worry too much?
  2. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    not a good idea to overfill the crankcase, a little is ok but i would have it fixed at the dealer
  3. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    [font=Comic Sans MS:6e6863030b]Don't worry about the slight overfill on your oil, that's the way they come from the factory. The thing to keep in mind is that your Prius is well engineered and will protect itself from both high and low battery charge. 70-75 is a little fast to start, but probably won't hurt anything. MPG improves as you learn how to drive the car and the ICE breaks in.
    Relax. Enjoy. You're driving the smartest car on the planet.[/font:6e6863030b]
  4. yoyoman
    342
    117
    San Jose California
    Thanks. I will check the engine more often to see if any excess oil spill out.
  5. yoyoman
    342
    117
    San Jose California
    Also, I'm looking for a mud guard. And I found this place www.metrotpn.com. $43+S&H and coastal tech is $55+ S&H. What is the difference?
  6. mehrenst
    mehrenst Member
    439
    San Jose, CA
    <div class='quotetop'>QUOTE(yoyoman\";p=\"107886)</div>
    IMO, using the cruise control for long drives on a new engine is probably not the best thing to do. The Owner's Manual also indicates long runs at constant speeds should be avoided in the first 500(?) miles.
  7. Bill Merchant
    4,096
    81
    Mud flaps/guards
    <div class='quotetop'>QUOTE(yoyoman\";p=\"107900)</div>
    [font=Comic Sans MS:1829d688d2]
    I got mine from Metro. Genuine, made-in-Canada Toyota parts. I can't speak to Coastal ETech's guards since I didn't buy them.
    Installation is easy, I did it myself.[/font:1829d688d2]
  8. silentak1
    silentak1 Since 2005
    893
    28
    LA
    I bought my splash guards on eBay for about $40-45 shipped... can't exactly remember, but search on eBay and yee shall find 'em.
    I'm averaging 47mpg on my Prius with only 450 miles so far... (I live in California so it's hot + i'm using A/C).
    Don't push 70-75, you don't want pre-mature wear on your internals. Try 65.
  9. priusham
    priusham New Member
    525
    Michigan - land of everlasting snowflake icon!
    Does the manual REALLY advise against maintaining a constant speed during the first 500 miles?
    Considering that the Prius does not have a typical transmission and that the ICE is constantly changing RPM to suit the power requirements - that advice does not sound correct - or even possible.
    I only recall the manual said, no hard braking, no hard starts. In other words... take it EASY...
  10. Tideland Prius
    16,157
    The cruise control for 300kms and the steady speed for xkms don't apply for the Prius since the PSD varies anyway
  11. yoyoman
    342
    117
    San Jose California
    Thanks. I just ordered it. Mudguard $43 & Ground S&H $7.74 = $50.74 total.
    <div class='quotetop'>QUOTE(Bill Merchant\";p=\"107907)</div>
    [font=Comic Sans MS:fbbadc7184]
    Installation is easy, I did it myself.[/font:fbbadc7184]
    [/b][/quote]
  12. silentak1
    893
    28
    LA
    and remember no cheap gas!!
    Shell, Chevron, or 76 only
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    <div class='quotetop'>QUOTE(priusham\";p=\"107921)</div>
    nope
    did a search of constant speed and the only time it came up was when describing the difference between series and parallel hybrids.
    obtw...besides the owners manual, i also search the Diag, service bulletins, new car features (that is where this reference is from) repair manual and campaigns.
    — REFERENCE —
    Series Hybrid System
    In the series hybrid system, the engine runs a
    generator, and the generated electricity enables the
    electric motor to drive the wheels. This type of
    vehicle can be described as an electric car that is
    equipped with an engine-driven generator.
    Equipped with a low-output engine, the engine is
    operated at a practically constant speed in its most
    effective range, in order to efficiently recharge the
    battery while the vehicle is in motion.
  14. yoyoman
    342
    117
    San Jose California
    I just got my mudguard today from www.metrotpn.com. Nice quality and good/easy work instruction. I like it.. I will put it on Saturday.
  15. Bill Merchant
    4,096
    81
    [font=Comic Sans MS:b7f3556356]Yoyo, use the extra screws (which you need to buy) as described on installation threads. The inboard edge of the rear flaps will wave in the wind, otherwise.[/font:b7f3556356]
  16. yoyoman
    342
    117
    San Jose California
    There are screws came with the package. 3 screws for each mudguard. Need to drill with the mudguard as templete. How many screws did u put on?
  17. silentak1
    893
    28
    LA
    3 screws per mud flap.... no slapping so far.
  18. flyingprius
    flyingprius New Member
    152
    Daytona Beach, FL
    Yoyoman,
    Congratulations on your new Prius! Don't worry about the gas mileage on I-25; mine was pretty low when I started first got mine. Yesterday I drove down to Albuquerque from Santa Fe at 80 mph the whole way and got 55 mpg... of course I dropped 2000 feet in elevation. When returning to Santa Fe around 1 this morning I got around 45. Going up La Bajada hill will destroy your gas mileage and drain a lot of your battery if you try to climb it at 80 mph. Don't get me wrong, the car will climb the hill, but the engine noise increases quite a bit. I usually go into the far right lane and climb it at 65 mph if I'm not in a hurry and the car does fine. I also keep the tires inflated at 42 psi in the front and 40 psi in the back. I only use Chevron, Shell, or Phillips gas. The Phillips on Alameda and I-25 usually has pretty cheap gas and it's top tier. Your gas mileage will improve with time as the engine breaks in and you become more familiar with how to drive it.
    Happy driving!
    Flyingprius
  19. IALTMANN
    IALTMANN New Member
    725
    What about Exxon Gas...I've heard the Chevron Gas or Shell gives NOTICEABLE improvement in mileage, is that true.., and is it the standard, mid grade or high grade.. and how much gas MPG savings if anybody knows or has done this before??
  20. vande23
    vande23 New Member
    St.Paul, MN
    I went and picked mine up yesterday in Duluth, MN - about 150 miles away. On the way home, I started out at about 70mph on the cruise and no a/c in 74 degree weather and watched the MPG hit 49.4 for about 50 miles. Then I went down to 67-68 (after remembering reading these posts about going too fast the first 500 miles) AND the a/c needed to get on cause I think the humidity was about 1000% pct! Then I dropped down to about 47mpg. Still, very happy considering I have heard of much worse for first drives needing a/c.
