Second ScanGauge II for GenII Prius
Discussion in 'Gen 2 Prius Accessories & Modifications' started by WilDavis, Jul 4, 2014.
  1. WilDavis
    WilDavis Senior Member
    2,492
    2,153
    49
    I've just ordered a second Scangauge II for my Gen II Prius and was looking for suggestions for the 4 X-Gauges I might use it to display. My existing SC is currently set to display: (1) Engine RPM, (2) Secondary (12V) battery voltage, (3) Traction Battery Current (-/+), (4) ICE coolant temp. I was looking for oil-pressure, but am not sure if that's available. Also, I see that BT2 temp is useful (it's in the middle of the stack, and tends to be the hottest). Any suggestions? Thanks in advance! - Wil
  2. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    No oil pressure since Prius only has low pressure switch. The way the ICE turns off and on the pressure would probably be confusing.
    In our hot weather I monitor HV Battery Blower intake air temp BtT, Cabin temp RmF, BT2 as you indicate and CF0 which is blower fan speed in percent.
