Secret Codes
Discussion in 'Gen 2 Prius Main Forum' started by lencap, Jan 8, 2007.
  1. lencap
    lencap Junior Member
    22
    HI All -
    I turned off the beeping function when the car is in reverse by reading about it on this forum. I've forgotten the poster's name, but a big thank you for the tip.
    My question is What other tips are there that provide more useful choices for the owner? Someone suggested that there is a list of dealer adjustable settings, including one to increase the light intensity of the steering wheel lights at night. Does anyone have such a list, or is it available in another section of the forum?
    Thanks for the help.
  2. Rainer
    Rainer New Member
    <div class='quotetop'>QUOTE(lencap @ Jan 8 2007, 09:31 AM) [snapback]372434[/snapback]</div>
    could you forward the instruction how to switch off the beep to me, I only joined the forum.
    Furthermore have you come accross a message dealing with the dispaly brightness, to me it's way too bright during darkness.
    Thanks
    Rainer
    Furthermore have you come accross a message dealing with the display brightness, to me it's way too bright during darkness.
    Thanks
    Rainer
  3. Warwind
    Warwind New Member
    137
    Hedgesville, WV
    If you click the Search button above, and enter "disable reverse beep" you can find the steps.
    Here's another thread (found using Search) that has lots of other interesting tips:
    http://priuschat.com/index.php?showtopic=26694&hl=
    The Search button is your friend! :)
  4. Charles Suitt
    Charles Suitt Senior Member
    1,637
    16
    Dallas TX
    Thanks
    Rainer"
    Have you read your Owner's Manual regarding the dimmer switch on the lower panel left of the steering wheel? This dims both the speedometer panel and NAV screen.
  5. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    <div class='quotetop'>QUOTE(Charles Suitt @ Jan 8 2007, 07:12 AM) [snapback]372448[/snapback]</div>
    Assuming you mean the MFD, there's a dimming control to the left of the steering wheel. You'll have to look for it. It's rotates in the vertical direction.
    When the headlights are on, it controls the speedometer, etc. and the MFD.
    Dave M.
  6. auricchio
    auricchio Member
    921
    Cambria, CA, USA
    On the 2006, the dimmer knob only affects the speedometer display. The MFD is adjusted by use of its "Display" button. You get to set brightness and contrast for both the Day and Night modes. (In the Day mode, the settings adjust the Day brightness and contrast; at night, they adjust the Night mode.)
    When the headlights are on, the MFD flips to Night mode. If you then turn the dimmer full up (e.g. at dusk when it isn't very dark), the MFD will flip to day mode. When you dim again, the MFD reverts to night.
    The steering wheel illumination is at a constant level and does not change with dimmer settings. There is no known dealer adjustment for this.
  7. Half_Orc
    Half_Orc New Member
    17
    Does anyone else Love the dimmer feature as much as I do? I use it almost every day.
  8. SomervillePrius
    SomervillePrius New Member
    944
    Somerville, MA
    I wish the "night mode" was automatic, I leave my headlights on all the time and I wish they had an additionl sensor to detect ambient light.
  9. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    The intensity of the steering wheel lighting is not adjustable by the driver, but I've heard that the dealership may be able to do that for you(?)
  10. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    You are incorrect the dealer can adjust the lights of the steering wheel and window controls with the Toyota Prius scan tool.
  11. fphinney
    fphinney Member
    234
    Walnut Creek CA
  12. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    <div class='quotetop'>QUOTE(FBear @ Jan 8 2007, 01:40 PM) [snapback]372638[/snapback]</div>
    I'll be looking into this. Thanks.
    What about the MFD coming on bright at night? It takes over 5 minutes for the display intensity to automagically drop down to the setting on the bar. Yes, you can override this each time you drive off at night but that's a pain and not what that feature was for. The MFD should dim immediately to the desired setting when the lights are turned on. Any way to _fix_ this? Toyota of course says "no". Thanks.
  13. Tideland Prius
    16,195
    It should dim immediately. I'm not sure why it takes 5 mins....
