Secret Doctor Conferences...
Discussion in 'Fred's House of Pancakes' started by Mystery Squid, Jan 12, 2006.
  1. Mystery Squid
    Mystery Squid Junior Member
    So, I've been told, by a good friend of mine, that, periodically, Doctors get together (behind closed doors), and discuss various mistakes they've all made. Since we have several Doctors on board, I wanted to see if I could verify this "hearsay"....
    Is it true? Do Doctors periodically sit around and discuss all the mistakes they've made?
    :ph34r:
  2. Salsawonder
    Salsawonder New Member
    1,897
    47
    La Mesa California
    As a nurse of 20+years I can guarantee you that Doc's discuss their mistakes, so do the nurses (probably more than the Doc's cause sometimes they don't even know they've made a mistake!)
    No one is perfect, it is just worse for some folks to be wrong. The best we can do is learn from our mistakes and be good listeners, because if you listen, you learn.
  3. Mystery Squid
    True, true....
    I wonder though, at what point must a mistake be revealed? Like for example, if a "mistake" was made, and let's say, as a resultant, if the "mistake" was not revealed in a short period of time, someone would ultimately end up with a scar somewhere barely noticable, do you think most Doctors would keep their mouth shut to avoid being hit with some sort of malpractice suit? OR, would they attempt to position it as something other than a "mistake", thereby ultimately correcting the resultant, thus, no scar, while at the same time, lowering the risk of any malpractice suit? OR, would they simply confess to the "mistake", ultimately correcting the resultant, thus, no scar, and take the chance?
  4. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    They're not secret, but they are protected. We call them M&M--morbidity and mortality. And it's not just to discuss mistakes, but to discuss interesting or complex cases in an open forum to learn from and to improve patient care.
    It's similar to the FAA's way of reducing the pilots liability if they self-report an error.
    The only way M&M can work to improve patient care is if everyone can speak openly...the physician in question can be honest about his mistake and others can be honest in their criticism and critique.
    Nothing discussed is discoverable in court.
  5. skruse
    skruse Senior Member
    1,454
    97
    Coloma CA - Sierra Nevada
    Most medical practices have a "Quality Review" panel (hospital, clinic, county medical association) that meets monthly and reviews individual cases. Cases are referred to the panel or some cases are obvious and beg for review.
    The objective of a Quality Review panel is to identifiy mistakes, errors and omissions, identify protocols and practices that should be followed, and share findings with other physicians. Hence, every physician has an opportunity to learn from the mistakes of others. Related medical disciplines often come together with physicians to learn from QR panels (dentists, nurses, pharmacists, attorneys).
    The goal is preventative medicine to better serve the public, not hide mistakes and conduct business in secret. We all benefit from QR panels. A physician, nurse or technician will be criticized for not paying attention to QR panel findings. Information frequently is dispersed to others - paramedics, laboratory technologists, fire fighters, educators, police officers.
  6. Mystery Squid
    Then who decides/judges the ethics behind various situations? Something amongst the lines of my example above.
    I most certainly agree there should be an open, yet protected, forum for these discussions, but I would imagine, there's also some sort of governing ethical concept behind it whereas there must be SOME level of disclosure if there is some sort of impact to the patient right? Or is it much like a church confession?
    Being totally crude to illustrate the point more effectively, if a Doctor within one of these sessions raises his or her hand and says, "Hey, I made this mistake, and as a result, if I don't go back and fix it, this will be the result". What then? Does the ethical responsibility fall upon the individual, or otherwise?
    If you're wondering "why" I'm bringing this up, simply for no other reason than I think it's interesting discussion that probably isn't discussed too often, and most people probably have no idea this sort of thing goes on. :ph34r:
  7. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    As I do surgery every week, I have to go through a process of "Informed Consent" with the patient prior to every surgery. One of the things I tell them is that surgeons make mistakes at sometime in their life and it's not a matter of if, but when it happens to one of us. I tell them that we might accidentally injure their bladder, intestines etc, and the surgery may even lead to death. If after that they consent to the surgery, at least they understand the risks.
    I can honestly say that I've never made a "mistake" as far as I know. But I'm young...it will happen to me one day.
  8. efusco
    19,891
    1,192
    Nixa, MO
    I guess the thing you have to keep in mind is that the physicians who participate in M&M are interested in giving the best possible care. Those who habitually do not or who do not correct their mistakes or who intentionally allow patients to be harmed are dealt with via our legal system and through the state licensing boards.
    Generally cases are resolved already when discussed...the M&Ms are usually 'after the fact' meetings. In those cases where a physician is still involved in a patient's care it is at that physician's discretion if he's going to follow the recommendations of the group, but I have never encountered a situation where solid advice wasn't heeded. It's a chance to reduce one's liability by correcting the problem, failure to do so increases the liability.
  9. Mystery Squid
    That's right! I totally forgot about the consent form just prior to some sort of procedure. Of course, that brings up another thought, given this consent, how much liability does it exclude? Obviously, if the consent was "all encompassing" there would be no need for malpractice insurance... except, I would imagine, for very gross circumstances...
  10. Mystery Squid
    Ah, usually "after the fact".... Thanks for the clarification... I guess between, personal ethical behavior, the "informed consent", and these M&M-type meetings, there's a decent cross-check "net".
    You have to understand, I'm rather paranoid, and don't believe anything anyone tells me, so I have to explore these issues... :lol: :) Plus, I've come across some "curious" situations when taking various family members to see Doctors. No offense to the medical professionals, but too many people are simply willing to believe what a Doctor tells them simply because they are Doctors. Of course, this applies to almost any field, not just medical, but when it comes to personal health issues, you tend to take them a wee bit more seriously.... (at least I would lol) I will, of course, digest this info. and ponder it further....
  11. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    Short answer is none...but if there is no documentation of a discussion of the risks of surgery, then as far as the lawyers are concerned, the discussion never happened.
    However, it gives you a legal leg to stand on. The plaintiff can't argue that, "If I had known xxxx was possible, I never would have had the surgery." It was actually a lawyer who recommended we include "death" in every consent. He said that if someone understood they could die as a result of the surgery and consented, how could they claim that the scar through a tatoo would have been unacceptable.
  12. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have to say that we are constantly trying to improve in the hospital, the clinic and everywhere. Yes many of these are privileged, or protected. The purpose is to improve and take it from me some of this is brutal. A M&M conference can be a turn over coals. Most of us try to do better and better. Are there bad eggs. Yes but they no longer last very long if they have privileges at a hospital. I would ask two questions of a doctor. First are they Board Certified in their specialities? Second do they have privileges in the local hospital? Docs in groups check up on others, Docs alone are well alone. That is not to say they are bad, but if they are not in any group no one is looking over their shoulders. We are not very tolerant of Docs who are not towing the line.
  13. DocVijay
    DocVijay Active Member
    1,455
    Tampa, FL
    Well this has been pretty well covered. Since I have now moved from medicine to the wonderful field of law (school), I'll be able to fill in the other side in a couple of years.
  14. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    Squid does rate himself 83% paranoid. :p
  15. Jack 06
    Jack 06 New Member
    2,556
    Winters, CA: Prius capital of US. 30 miles W of S
    I don't worry about the ethics of doctors in relation to their medical care. (If I were a woman I'd worry more, especially about cosmetic surgery, after all the evidence you see on TV and the 'net about all the botched breast enhancements and other cosmetic procedures, but that's a branch of medicine I have no use for.)
    The ethics I do worry about is the prodigious fraud engaged in, I suppose mostly by group practices, in ripping off Medicare, Medicaid and insurance companies. All of us, as taxpayers and insured people, pay for these "white-collar crimes" through higher taxes and premiums. The perpetrators seldom lose their licenses. Is it possible to have a "high sense of medical purpose" and still engage in massive overbilling and billing for services never rendered, sometimes to nonexistent patients?
    I'm sure docs don't admit these "mistakes" in their private sessions. We have to spend even more taxpayer money to catch and prosecute them.
  16. DocVijay
    1,455
    Tampa, FL
    Those are not medical errors, and would not be covered in a M&M meeting. That is called insurance fraud, and can be committed by anyone in the office, not just the doctor.
  17. Mystery Squid
    Now THAT'S one of those "darkly" brilliant concepts...
  18. Mystery Squid
    I hear you. There are bad apples in EVERY field, thankfully though, your chances are decent that you won't run into any. Even I have to say the bar is set pretty high, so to speak...
    Funny how a stupid admin job when I was really young actually paid off. The questions you mentioned, are basically what I used to do for a summer job: making sure Dr's were board certified and had appropriate hospital privileges for an HMO...
    Anyway, I guess where I'm also going with this (here come the groans!), is the tremendous cost of healthcare these days. IMO, it's flat out wrong, and highly unethical to have to "drain" all your assets to simply acquire various amounts of healthcare. I know Dr.'s have to carry certain minimums of malpractice/liability insurance, and the premiums are insane (I'm sure you'll all agree?). Then again, multi-million dollar settlements seem all too common these days, which in turn drives up the costs of care, blah, blah, blah, you all know the hash...
    The whole thing about draining assets just pisses me off. :angry: It's one of those things seems to require some sort of planning for, even though I'm technically 32. Obviously, the best thing to do is not get sick, but well, obviously that's a crapshoot...
  19. Mystery Squid
    Jack man, you've got it upside down...
    I'd worry about the ethics first, as that has the ultimate impact: potentially on your life.
    All else is secondary...
  20. Mystery Squid
    Now this is interesting...
    Why would one do that? If you don't mind?
