Secrets to Maximizing Prime features
Discussion in 'Prime Main Forum (2017-2022)' started by Here2HaveFun, Jun 14, 2018.
  1. Here2HaveFun
    Here2HaveFun New Member
    2018 Prius Prime
    Hi ALL,
    I'm a proud 2 month owner of a 2017 Prius Prime Advanced. I'm thankful for this website as I'm learning so much about this car. I have questions which I hope you can answer so I can start maximizing the Prime features. Typically I drive both in the city (40mph) and highway (average 70-75mph) on a daily basis.
    1. I have been averaging 28-29 EV miles after a full overnight charge. How does one get up to 32-36 EV that I have been reading about?
    2. Since the car defaults to EV mode when I first start the car, should I put it into ECO mode so it warms up, and then switch to EV mode minutes later as I'm driving thru the city streets?
    3. Likewise, should I switch to ECO mode once I'm on the freeway?
    4. If I'm on the freeway in ECO mode , would you recommend putting the car in CHG mode to recoop EV miles (up to 80%) and then switching to EV and continue driving to deplete the EV miles, and then go back to CHG mode again, then EV, etc? (FYI--- San Diego gas is currently $3.45/gallon, and I'm paying .22 for electricity during Off-Peak hours.)
    5. I love the self-parking in parallel mode or backing up in a parking lot space. However, the car doesn't look like its "centered" in the parking lot space. What am I doing wrong?
    Thanking you ALL in advance!
  2. PT Guy
    PT Guy Senior Member
    1,085
    712
    Washington, the state
    1--that depends on the hvac & seat heater. You're certainly not running the seat heater, so if the air temp is Goldilocks--just right and the heat pump neither runs for AC nor heat, the range is increased. And it depends on speed & traffic conditions.
    2 & 3--the word Mode is used too much. EV & HV mode relates to whether the electric motor or the gasoline engine runs. ECO mode relates to how much acceleration you get from a part-push on the accelerator pedal. Whether you're in ECO, or Normal, or PWR, zero pedal is zero acceleration. Floor boarded is always max acceleration. Part pedal is...less for ECO, more for Normal, even more for PWR. If you draw a pedal-position vs. acceleration graph, Normal is a straight line from zero to maximum. ECO starts off low at the start, then rises to max. PWR rises fast at start then flattens toward max. Not a big deal. So...pick the mode that feels best to you for your driving and stick with that.
    4--probably not, but somebody with a sharp pencil may provide a detailed answer.
    5--it does a pretty good job. It's not perfect.
    52,390
    welcome!
    the slower you drive, and the less you use ev on the highway (same thing) the higher your ev estimate will go.
    but that won't give you more ev miles when you speed up or drive more on the highway.
    you can't change anything really, it's just an estimate of your past driving average.
    put it in hv mode before you get to the highway, so the engine warms up a little before you need full acceleration.
    leave it in eco mode for best mpg's and ev range, until you've had a chance to experiment with normal and power mode to see how they compare.
    charge mode is less efficient than just driving on the engine.
    all the best!(y)
  4. SteveMucc
    SteveMucc Active Member
    391
    268
    Kentucky
    I've actually used the "un-parallel-park" feature, in of all places, the Toyota dealership. I went in for my 20K maintenance and after they were finished my car wish in a bumper-to-bumper long line of cars. It actually worked really well. All I had to do was to switch back and forth between forward and reverse and the car rocked itself out of the spot. took about 10 forward/reverse cycles (like I said, it was in there tight), but I was fairly impressed by it. Is it a bit of a gimmick? Hard to tell, I used to work in NYC so can parallel park with the best of them, but for someone who doesn't do it regularly or hasn't in a long time, it sure beats trying to re-figure it out in traffic or with people blaring at you.
  5. Dudley1030
    Dudley1030 Active Member
    200
    139
    Lawrence, KS
    Turn the HVAC from Auto to off when the weather is nice. That will get you extra EV only miles. Hills will kill your EV miles. When I am in a hilly area I sometimes use EV AUTO. It uses the ICE more on the hills and EV when there is less load on the ICE.
  6. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    Recommend keeping ac, screen, seat heater, and anything requiring power off I suggest using Bose Frames for audio since they don't obstruct your ear and are much more fun to use.
  7. bisco
    52,390
    last seen: 1 year, 5 weeks ago. guess he didn't have that much fun :unsure:
  8. Witness
    Witness Active Member
    115
    117
    San Francisco Bay Area
    UN-PARALELL PARK?! I can parallel park great, but yes there are times when you're squeezed. I did not know it works in the opposite direction. Thanks!
    iPhone ?
  9. PT Guy
    1,085
    712
    3--See what you like. This is about Eco-Normal-Pwr accelerator pedal modes, not the electric or gasoline power modes. We like Pwr on the freeway for quicker scoot getting into a gap in traffic.
    4--I'm not sure anyone has ever found a good use for the charge mode. Why burn gasoline to charge the battery???
  10. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    People always blame the seat heater, but I wonder how much power it actually uses and how much is just loss of capacity because of cold weather? It can't be more than 100W, which is nearly insignificant for the Prime. Even if it's 100W each you'd lose only about 3% of the stored energy driving around with them on for an hour. One of these days while it's still summer I'll have to drive to work with both seat heaters on high. It won't be pleasant, but I'm willing to sacrifice comfort for science.
    Shaunius and Prius from Dad like this.
  11. Blauer Glimmer
    Blauer Glimmer Active Member
    448
    169
    NY (Southern Tier)
    My one good reason for charge mode: to make sure you have enough EV power to preheat or pre-cool for the return trip if you can't plug in at your destination.
  12. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    • When driving up a mountain you could use it when you're close to the top so you can use B mode in EV mode on the way down (B mode in EV mode doesn't run the engine, but in HV mode it does)
    • You might use it if your next trip is very short to avoid a warmup cycle
    • You could use it if you're going camping or sleeping in the car and want to run the climate control without the engine. This could also be useful if you have an inverter and want to run it for a while in a remote location without using gas
    • If you need maximum range on a long trip you could use it to top up the battery before getting gas
    • If you're doing a short trip where the engine doesn't have time to thoroughly warm up, you could use it to put additional load on the engine, to try to avoid condensation in the oil or exhaust. There is the automatic warmup cycle, but it doesn't get the engine that warm.
    • I have used it when someone wants to try driving my car in EV mode, but I don't have time to charge.
    • As mentioned above you could use it if you want pre-conditioning to be available for your next trip
    jerrymildred and benagi like this.
  13. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Welcome to PriusChat !
    1) Consider running a bit more PSI in your tires to achieve better MPG's.
    2) Try leaving it in ECO (throttle mapping) indefinitely.
    3) Drive it smoothly for best MPG's.
    4) Use A/C sparingly for best MPG's
    5) You can use your 120v OE Toyota EVSE at 240 volts for fast 2 1/2 hour charging, if you have a near by 240v outlet.
    Rob43
  14. bisco
    52,390
    last seen 1y, 5w ago
    jerrymildred and Tideland Prius like this.
  15. Tideland Prius
    16,616
    Estimated EV penalties for various heating cooling and lights | PriusChat
  16. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    UGH,
    I can't believe I MISSED THAT !
    LOL at myself,
    Rob43
