security system
Discussion in 'Gen 2 Prius Technical Discussion' started by Beachbummm, Jun 13, 2014.
  1. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    I thought when the car is running and you walk away with the key fob it will shut down after a distance, I know the yellow light flashes, I left my Prius running and a friend decided to take it for a ride without me, I still had the smart key... 10 mins later he pulls back into the driveway and I was expecting a call saying the car shut down.. I assume the smart key is needed to restart the car but if its running they can drive it away and keep going, its not anti theft system I thought it was..
  2. Squirt
    Squirt Member
    204
    47
    Los Angeles
    2014 Prius Plug-in
    This is the case for most/many keyless systems. I've made this mistake with rental cars and valet parking more times than I can count. They get the car parked before they realize there's no key fob to lock it.
    I believe it's sort of a safety feature. Can you imagine the key fob battery giving out while underway on the highway, so it loses contact with the car? If the car were to simply shut down at some point, I think it would be a big problem.
  3. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Squirt has it correct. All SKS's work this way for safety reasons. The car never automatically shuts down. It tells you when the key is no longer recognized and it is up to you to know why. If you leave it READY, it will remain READY until all petrol is burned up and the HV battery is drained to a couple of percent.
