Security Warning Light Flashing?
Discussion in 'Gen 3 Prius Main Forum' started by jangell2, Jan 12, 2014.
  1. jangell2
    jangell2 Junior Member
    82
    Maumelle, AR
    I've got a 2010 4-door hatchback and yesterday installed replaced the factory radio for one from crutchfield. I detached the negative battery cable to do the work. After all is done and everything is working, I noticed the red security warning light is flashing constantly.
    The owner's manual says that when the power button is turned off, this light will flash. That's about all it says. It could mean continuously until the prius is turned on or it could mean it will flash to let you know it's ok and than stop.
    Neither my wife or myself remember whether this is normal behavior. Having just done the receiver install it concerns me. I called my dealer on Saturday, and the guy I talked to remembered there was a light that did flash continually, but he couldn't name it, and wasn't going to research it for me.
    Help me gain a sense of security (pun intended) and confirm this is normal behavior, if you can. Boy you'd think we'd remember this ourselves since we bought the car new.
  2. frodoz737
    frodoz737 Top Wrench
    4,719
    2,517
    33
    Mines been on since last night and it's always been that way when powered down. Hope that helps.
  3. El Dobro
    El Dobro A Member
    7,090
    3,270
    As long as the car is off, the security light will flash, letting people know that it has a security system and it's working.
  4. jangell2
    82
    Maumelle, AR
    Yes, that helps. Particularly the "always been that way" part. Thank you.
  5. frodoz737
    4,719
    2,517
    33
    ...even if you do not have one. ;)
