See Video 2010 P Lock Malfunction, Shift to P position, Red Triangle
Discussion in 'Gen 3 Prius Main Forum' started by Aldomontas14, Mar 3, 2019.
  1. Aldomontas14
    Aldomontas14 New Member
    125000 miles
    I bought a Mini VCI with TechStream. to read all codes. But have not received yet
    Replace Remote battery
    Replace 12v Battery (12.7 V right now)
    I really appreciate the help in advance. Thanks
  2. Aldomontas14
    Please help, Gracias
    52,362
    welcome!
    toughest problem on a prius. could be a bad actuator. how are you measuring the 12v?
    make sure all your doors are closing properly, especially hatch
  4. Aldomontas14
    thanks for the response....Its a new battery, due to everyone attacking the battery as first in the list, was the first I did. Them went from the easiest steps to the hardest one. Its was the long gray relay in the fuse box. The gear connect to the relay, the really connects to the shift actuator, so basically the command never was getting to the transmission.
    Raytheeagle, SFO and bisco like this.
  5. ericbecky
    ericbecky Hybrid Battery Hero
    4,443
    3,351
    Madison, Wisconsin
