Seeking advice for likely head gasket issue
Discussion in 'Gen 3 Prius Main Forum' started by J Philip, Oct 14, 2024.
  1. Absolutely
    0 vote(s)
    0.0%
  2. Probably
    100.0%
  3. Probably Not
    0 vote(s)
    0.0%
  4. Only if you want to destroy your engine
    0 vote(s)
    0.0%
  1. J Philip
    J Philip New Member
    Lakeland, FL
    Short version: If the startup rattle / check engine light came on 3 drives ago, (i.e. I've started the car three times and driven it since the first start rattle) and no other symptoms are obvious (coolant fluid, leaks, oil level/cleanliness) is it likely ok to drive a bit more (1-5 times) without causing lasting damage to the engine?
    Long version: 2013 model 2 with 202k on it. I got a check engine light 4 months ago that coded for cylinder three misfire. As it was at 195k at the time, I went ahead and replaced all 4 plugs and coils. No check engine light or performance issues between then and last week when the startup knocks began. After the issue started, I drove it twice more, read many threads here, got the codes and haven't driven it since. It showed cylinder 2 and 4 misfires and multiple cylinder misfire codes. (P302,P304, & P300)
    Once it warms up, it doesn't knock, which leads me to believe it is a head gasket leak. I'm ordering a combustion leak detection kit to confirm before moving on any repairs, DIY or real expensive.
    The reason for this post is as above, I have need to drive it a few more times before I can realistically work on it as our second Prius (my wife's) is needed by her once in a while. What is the gut reaction to those of you who have more experience with such things on whether or not I can "safely" get away with driving it a bit more? I fully understand that any opinions offered are no guarantee of anything and things can go wrong at any time. That said, I'm looking for group opinion on the matter.
    Thanks in advance.
  2. ColoradoBoo
    ColoradoBoo Senior Member
    1,132
    741
    Monument, Colorado USA
    One thing our Prius' don't have is a coolant temperature gauge....how dumb not to let us see just how hot that coolant is!!
    How far are your trips? No white smoke blowing out when she first starts or after sitting like at a light??
  3. Mendel Leisk
    40,550
    That kit I suspect will check for exhaust in coolant, which is not what happens, at least not in the early stages; it's more likely to be leaking coolant into the cylinders, and boroscope inspection of the engine's combustion chambers seems to be the DIY go-to for this.
    The more typical starting misfire code is p0301 (cylinder one). Considering the codes are cylinders two and four, AND the miles on it, it sounds like head gasket failure well along. Maybe enough that the kit you've ordered will detect exhaust in coolant.
    Has the EGR system and intake manifold ever been cleaned, and if so when?
    Krall likes this.
  4. J Philip
    J Philip New Member
    Lakeland, FL
    My round trip is 80 miles, or if I let my wife drive the ticking time bomb, about 15 miles.
    No smoke or other signs present.
  5. J Philip
    J Philip New Member
    Lakeland, FL
    The test is definitely for combustion gases in cooling system. The video that drove me there made the point that if it is leaking while at rest, while under combustive pressure, the leak should go the other direction, which will drive the gases into the cooling system, which is why this test is a "definitely your head gasket" kind of test. The logic sounded reasonable. While I understand the boroscope inspection would be ideal, that is a more expensive tool that I don't have and would have very little use for regularly.
    As for the EGR system, I didn't know anything about it until this happened and I read all your threads. Your signature page is very helpful by the way. So to answer your question, never. Given the symptoms and age, I'm hypothesizing the gasket is leaking and the gas test will confirm. (I'll know this weekend) I'm sure the EGR will also be dirty at best and near blocked at worst, but if I need the gasket replaced, the EGR cleaning will just be along for the ride.
  6. Krall
    Krall Member
    125
    37
    NY
    My 2010 would knock/shake a little bit at first. Got the EGR circuit cleaned out and it would still do it from time to time. I can't remember how many more miles I put on, but it would then knock/shake all the time even when driving and that's when I knew it was game over.
