Seeking Pictures of Hidden Hitch installed (2010+)
Discussion in 'Gen 3 Prius Accessories and Modifications' started by yyyiiikes, Oct 11, 2011.
  1. yyyiiikes
    yyyiiikes Junior Member
    84
    Austin, TX
    Many threads about towing and hitches... could not find a picture of the Hidden Hitch installed? Please post if you have one. I would like to determine how "hidden" this hitch model actually is.
    Thanks!
  2. chickenhawk
    chickenhawk Member
    261
    95
    CA
    If you are referring to the eyebolt that is located with your spare that attaches to one of the small squares in front bumper when you take the square off ..its in the manual.
  3. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  4. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    from what i've seen.. for a prius they are all basically the same. some are built better than others.. but they all stick out to a point. they will all tow more than the car can handle.
  5. chimo
    chimo Junior Member
    81
    Ottawa, Canada
    Sorry, not a great pic - it's dark outside.
  6. yyyiiikes
    84
    Austin, TX
    Chimo - Thanks much for posting up the picture!!! I owe you one.
    Jimbo - good info! I had no idea that they were owned by the same company and probably the same product. No wonder they look so similar! :rolleyes: Internet search indicates that even Reese is owned by the same parent company.
    Etrailer has both brands listed with the exact same spec but with different prices. Draw Tite label is less expensive - the decal must be $20 cheaper. :D
  7. yyyiiikes
    84
    Austin, TX
    This is a truly "hidden" hitch:
    from Torklift Central (in state of Washington). Very inconspicuous.
    Unfortunately, they did not respond to my query for information. Anyone here using this one?
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Silly Aside: In my youth I drove by Torklift Welding - Trailer Hitches in Kent WA.
    I misread their sign as Forklift Weddings - Trailer Hitches which puts a whole different spin on Trailer Hitches, it is a flatbed wedding.
    As I watched the two videos, the Drawtite did not require any plastic undercarriage removal, One person did the entire install while talking, while the Hidden Hitch is all about carving the plastic up to get it to fit after installation of the hitch.. I sure would not consider the Hidden Hitch a self install., at one point it took three techs
  9. txl146
    txl146 Member
    301
    NY
    Has anyone run into a problem where dealer tried to void the warranty upon seeing the installed hitch?
  10. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    Is this for a bike rack? Just curious what's being towed by a Prius?
  11. Qyota
    Qyota Junior Member
    Bemidji, MN
    I'd use it for my bikes.
  12. yyyiiikes
    84
    Austin, TX
    Yes. For bikes is the primary purpose. It can also be used with a cargo box.
    Others have used hitches for towing light weight trailers like a kyak.
  13. DJ2010
    DJ2010 New Member
    Georgia
    Try this link Prius Stealth Trailer Hitch you may order one now, free shipping to the 48 States. This hitch appears to be more heavy duty than the curt hitch and comes in both 1.25" or 2" varieties.
  14. Ajvdub
    Ajvdub New Member
    51
    La Crescenta CA
    Stealth hitch sure looks like a lot of work. I got the Curt hitch, took me less than 20 min to do on my own, no trimming necessary. Draw Tite is the same deal, quick, trimless instalation.
  15. yyyiiikes
    84
    Austin, TX
    Agree, but I wanted the more stealthy look and willing to do the extra work with trimming. The company never responded to my emails so I gave up on that idea.
    I ended up going with a Draw Tite. Installation was easy... (after I had a neighbor hold the hitch in place while I threaded the bolts).
    Are you using it for a bike rack... which one did you go with?
  16. yyyiiikes
    84
    Austin, TX
    Just saw your post - thanks. This is the same company I attempted to contact. Had they responded, I would have purchased it. Very clean look.
  17. d0nsut
    d0nsut New Member
    28
    Houston
    Yakima Holdup
  18. yyyiiikes
    84
    Austin, TX
    Photos of my Draw Tite hitch doing it's thing! :)
    GaR619 likes this.
  19. Daddy Dave
    Daddy Dave Member
    94
    39
    Sheridan, WY
    The others have posted decent pics so I won't bother. Mine was an easy install with the correct socket and long enough extension. I left off one bolt under the end of the muffler on the right side because I was lazy and couldn't reach it. I used a floor jack to position the hitch prior to bolting it down. I've only used it to hold a big luggage box for one long road trip so we could keep the area behind the seats reserved for the dog. Worked great once I re-welded the rack (not hitch) so it didn't drag on the ground over the smallest bumps.
  20. txl146
    txl146 Member
    301
    NY
    I want to see more picture of "hidden hitch" as it seems to have triangular shape, which makes it less visible.
