Seems Prius prevents an obvious use case for remote AC
Discussion in 'Prime Main Forum (2017-2022)' started by scm2000, Nov 1, 2017.
  1. scm2000
    scm2000 Active Member
    164
    125
    So the use case is... It's cold out... you stop to pick up a pizza, you shut the car off, get out lock the car.. and press AC Hold... In my world this would keep the AC on with the car off for the few minutes till I get back to keep the car interior warm.
    But the Prius specifically disallows this case. You can't activate AC Hold until 3.5 minutes after turning the car off.
    So I'm not sure what the meaning of AC Hold is then...
    Is this the intended use case? It's cold out... you turn off the car, lock it and go into a store, 10 minutes before you plan to leave the store,... you go outside close enough to the car to activate AC Hold, and then go back in the store, finish your shopping, leave the store again and get in your warm car?
    Is that it?
    priuscatprimeguy likes this.
  2. alexcue
    alexcue Active Member
    346
    311
    So Cal
    It must be to prevent unintended activation? But with the Advanced I'd just use the app while in the store.
  3. scm2000
    164
    125
    well it's actually preventing an intended activation ;)
    alexcue likes this.
    52,789
    why do you want a/c when it's cold out?
  5. scm2000
    164
    125
    AC is the name Toyota gave to the system that maintains a cabin temperature.. It could be heating or cooling... They call it AC.
    In the 07 prius.. The AC system either used the air conditioner, or engine heat to maintain a temperature.
    In the 17 Prime.. it consists of a single heat pump.. that either heats or cools... as far as I can tell... no ICE heat is used
    bisco and priuscatprimeguy like this.
  6. bisco
    52,789
    gotcha, thanks! ice heat is used when the battery is low, or when temp drops below 14 degrees i think.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    or........if you use the front defroster:eek:
  8. scm2000
    164
    125
    Ok thanks... I bought the car in the summer... so this is the first time I'm seeing it go into a winter... with outside temps in the 40's its using the heat pump... I'm eager to see how it goes in below freezing...
  9. bisco
    52,789
    why?, is my question. edit: sorry, that's for the defrost statement above.
  10. priuscatprimeguy
    2,730
    2,640
    you ask too many questions:rolleyes:
  11. bisco
    52,789
    yeah, i know. story of my life.:oops:
    CNYhybrid and priuscatprimeguy like this.
  12. scm2000
    164
    125
    Why do I want the AC system to stay on to keep the interior warm while the car is off and locked, while I run into a store?
    Because I like warm..
  13. bisco
    52,789
    sorry, i messed that up.
    scm2000 likes this.
  14. priuscatprimeguy
    2,730
    2,640
    because ICE (the actual ICE, you know frozan water) on the windshield, takes more heat than the heat pump can pump out
  15. bisco
    52,789
    thanks. then it should be user definable, for mist.
  16. priuscatprimeguy
    2,730
    2,640
    Well the climate function does defog the windshield (no front defroster needed):D
  17. bisco
    52,789
    cool! what is the climate function?
  18. scm2000
    164
    125
    Same question here... all I see is a button to turn on the defroster.
  19. priuscatprimeguy
    2,730
    2,640
  20. scm2000
    164
    125
    Ok... so if you drive with the AC system off... all your windows fog up... but that's not the same as saying the AC defogs the windows right?
