Selfish Leaf Driver versus Bad Circuit Breaker vs Power surge
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by JurassicPrius, Jul 21, 2013.
  1. There is a Park and Ride lot that I pass by on the way to work. Every day I notice a Black Leaf parked at a charging station within this lot. Today, Saturday, I thought I would drive to that lot, and plug in to one of the chargers, while I would jog along a nearby jogging trail at an adjacent park. There are two chargers located at that Park and Ride lot, one had a Tesla parked and charging. This one had a cone in front of the space. On the charger itself, there was a paper sign that said out of order. The charger also did not have the "Power" light on. I looked on the side of the charger, and there was a power switch in the off position. I turned the power switch on, and the charger powered up. I was able to charge without any problems. I don't want to suggest that a Nissan Leaf driver would mark this charger out of order, when he was not using it, so he could always have this charger available. On second thought it may be that the switch is a circuit breaker, and when a plug in Prius is using the charger, there is no problem. But if a Leaf uses this charger, it draws more current, and the breaker goes off. Or there may have been a power surge of some sort that threw the breaker, but now there is no problem.
  2. epi117
    epi117 Junior Member
    82
    oregon
    The title is misleading. Flames without the facts.
  3. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    I smell a rat. Name of poster, number of threads and content.
    Jurassic Prius, if you've nothing better to do, put your energy into something constructive like charity work. (y)
  4. Dan Cathy
    Dan Cathy Junior Member
    126
    There is another thread about an angry Leaf owner. It is starting to look like EV's are friendly for the environment but not friendly among people
  5. El Dobro
    El Dobro A Member
    7,075
    3,258
  6. Astolat
    Astolat Member
    229
    73
    Guildford UK
    Unless it's been changed, title seems fine to me, saying there are three possibilities. Having seen someone charging for a week, then found the cone and hand written note, and then that it could charge, there is at least grounds for suspicion. I don't think I signed up until I actually had something to say, so I'm not so surprised about his stats. And it actually seems to be non PiP Prius drivers who are getting at us the most here!
    JurassicPrius, maybe you need to check it again a couple of times and see if the cone and note is always there when the other car isn't. Once is happenstance, twice is coincidence, third time is enemy action... If it does recur, seems reasonable enough to me to a) mention the location here and b) check with the charging company whether the point has been out of order.
  7. iplug
    iplug Senior Member
    2,456
    1,704
    Rocklin, CA
    Makes sense to wonder if all is on the up-and-up, but if interested in pursuing this, good to have more facts, research this and ask questions diplomatically without pointing fingers. Seems like this would be high risk to get caught if someone was doing this as a personal parking space. Also, you mentioned you saw the note/cone on Saturday and most people work M-F, so could very well be unrelated to nefarious motives.
    Zythryn likes this.
  8. Zythryn
    Zythryn Senior Member
    6,406
    4,403
    I would guess Park & Rides may well have cameras?
    If the city put the charger in for the citizens, they may be open to scanning to see who put the note up.
    While it peaks the curiosity, it is a loose coincidence at this point. I would second the suggestion to get at least a second data point.
  9. bisco
    51,155
    a question mark after the title clears things up. sounds reasonable to me. i vote for 2 or 3.
  10. DadofHedgehog
    DadofHedgehog Active Member
    681
    282
    northern Virginia
  11. davidbw
    davidbw Member
    110
    29
    In front of my computer
    Today I was at the Encino Park and Ride at 5174 Hayvenhurst Avenue. There are two EVSE's at this lot. One of them does have a circuit breaker that seems to trip very easily. It tripped two minutes after I plugged it in, and five minutes thereafter. I gave up after that. While I was pulling away another EV came by. I turned around, and he was not able to get the thing to work at all. I guess because Prius's draw less electricity the circuit breaker is more forgiving...but the circuit breaker is on its last legs.
  12. stevemcelroy
    stevemcelroy Active Member
    873
    194
    Boulder, CO
    It would be easy to test. Flip the breaker and put the sign and cone back. Check on your way to work tomorow. If the Leaf is in the spot then you know.
  13. Vulcanman
    Vulcanman Junior Member
    68
    This makes me wonder - has it ever happened to anyone that they plug the EVSE into an outside outlet at, say, at strip mall and it trips a major circuit breaker that shuts down something major that was also sharing that same breaker?
  14. retired4999
    2,652
    625
    Eau Claire, Wi.
    I have only charged about 6 times at my brothers apartment bldg. Outside plug-in made for winter time, tank heaters to warm cars for starting, never had a problem!
  15. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    . Most outlets I have used have no other loads on them. AFAIK
  16. Electric Charge
    Electric Charge Active Member
    545
    133
    Syracuse, NY
    I've shut down a Chili's restaurant by using their new L2 ChargePoint charging station, does that count? ;)
  17. El Dobro
    El Dobro A Member
    7,075
    3,258
    It may have saved a lot of stomachs.
  18. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    946
    118
    Los Angeles Foothills
    Only 1 or 2 chargers in a big lot is pathetic! No wonder people play the cone game!
    How about 10 chargers, that are properly constructed, with sufficient size breakers so they won't trip at the first power jiggle!
    That would be nice!
  19. fuzzy1
    10,335
    Did they thank you for discovering an improper charging station installation?
    lensovet likes this.
  20. Electric Charge
    545
    133
    Syracuse, NY
    No, I was more concerned about them having a negative attitude towards EVs because of this issue, but in the end, they were very nice about it, and all of us learned some interesting lessons.
    I actually did a little write-up about this, because I really want EV drivers to help out businesses running into these type of growing pains.
