Sell one and keep one? A 2004 and 2013 Prius
Discussion in 'Gen 2 Prius Main Forum' started by Samantha Los Angeles, Jan 10, 2023.
  1. Samantha Los Angeles
    Los Angeles
    I am the original owner of a 2004 Prius (~100k miles) that I have kept in great condition. It's cat was stolen and I got an OEM replacement. However, in the meantime my husband who is the original owner of his 2013 Prius (~35k miles) got a different car and now we must decide which I keep. The 2013 had it's cat stolen and I think (he dealt with it and doesn't know) didn't get an OEM replacement. His has a cover now that seems to be deterring criminals. However, mine had a miller cat shield v.1 shield that only deterred them for so long before they found a way through. I'm desperately trying to get a custom cage installed ($350/400) on the 2004 before it is also taken, again or get the v 2 cat shield ($500-600.)
    So the choices are for me to keep or sell:
    2004 Prius. 100k miles, good condition, no accidents, well serviced, original battery, new tires, replacement OEM cat. No cat shield or cage yet. I don't have the package number handy but it was one of the top models.
    2013 Prius. 35k miles, great interior condition, some dents and scrapes to exterior, no accidents, not sure how serviced as he wasn't as good about taking it in, original battery, not sure on tires. Not sure if OEM cat. Has a cat shield, not sure of type.
    I'd love any and all considerations. He thinks no brainer to keep the 2013 but I'm attached to my car even though she doesn't have the pick up of his and has more years and more mileage. She also isn't scraped and dented like his. Thank you so much for your expertise and advice.
  2. Samantha Los Angeles
    Los Angeles
    I will add that I have a young child who is terrified of the sawing noise as they were here when it happened as the criminals left when I yelled at them but then CAME BACK 30 minutes later knowing we were awake and looking out our window. I don't have a garage (carport only) and don't want to be a target. My sleep is more important than my car. So, I'm considering just getting rid of the 2004 since it may be a bigger target than the 2013.
  3. Tombukt2
    Tombukt2 Senior Member
    13,405
    2,415
    Durham NC
    The generation 2 is the better car and we'll go the distance The generation 3 at 35,000 mi You've got 70 or 90,000 mi or so and you'll be needing an engine or head gasket more than likely If you have that kind of money keep the 2013 the catalytic converter thing seems to starting to be faltering a bit You should have your welding shop weld you up some spikes that go around your pipe ends at each end of the catalytic converter and a few other tricky things it can be done I don't know where you sleep I know people are defecating in the street in Los Angeles. Maybe it's time to think about doing something else I don't know thank God I am not anywhere out near that coast of the world I don't even visit their generally. Me personally I don't own a Gen 3 My wife my girlfriend and my daughter may My Gen 2 isn't going anywhere I don't care what happens to theirs I have to fix them but I have to make the choice whether they're going to keep or get out of We also have old Corollas and stuff here so we can drive many things not an issue All those cars are old and paid for and I can't get rid of them unless I cut them up and send them to scrap everybody else wants brand new cars and payments or similar I have no interest in any of that
    Samantha Los Angeles likes this.
    52,386
    both gens catalysts are being stolen, even though gen 2 is slightly more valuable. did you put on a shield?
    with your low mileage, you might want to consider corrola or such with less cat worries.
    if not, i would keep the one you like best. you are likely to have similar amounts of trouble with both, the 04 being so old, and the 13 having so many factory defects.
  5. Tombukt2
    13,405
    2,415
    Durham NC
    The Gen 2s are old I agree but they are gems. They are somewhat heavier duty and can take the thrashing most things you find wrong with a Gen 2 are cosmetic stains and fabrics that sort of thing that some people think they're too good to sit on or whatever but generally the mechanicals and what have you are pretty stout putting an engine in a Gen 2 I don't want to say is a rarity but then again I will say in my life it's been pretty rare to see work on motor generator one or two is a possibility again pretty rare The stories you read about that happening are generally at super high mileage possibly super high abuse by people that don't generally need to be owning cars like this boy racers and whatnot. I own both generations I am not exciting about getting a fourth or a fifth generation either so I look to be staying in my generation too maybe till I expire I'm almost 70.
  6. bisco
    52,386
    but there's also a difference between someone like yourself who can diy almost anything, and someone subject to dealer repair
  7. PriusCamper
    PriusCamper Senior Member
    13,051
    5,304
    Pacific Northwest, USA
    The 2004 is going to way more affordable to keep running over the next 10 years up to 300K miles compared to the 2013, which will likely need lots of expensive engine work before it gets anywhere close to 200K miles.
    Cat shields and other protective measures don't work at all in high crime areas... You need to find a place to park the car that's not on the street. Maybe rent a neighbor's garage?
  8. Samantha Los Angeles
    Los Angeles
    Thank you @Tombukt2 @bisco and @PriusCamper for your thoughts! I had a custom cage welded to the whole length of the 04's OEM converter this morning and have heard from others in the area it is the best thing around, better than shields. Takes about 6 blades to go through. According to the installer of the cage, California law requires OEM converters (on back order several months if stolen) for Gen 2 but the others can have aftermarket installed legally (much easier to get) so I went the route of a heavy duty cage so even if I don't keep it, I can sell it knowing that it is the best out there.
    I had a version 1 of the miller cat shield but they bypassed it through the wheel well. FYI that Miller is selling a "Dead Bolt" for about $60 that supposedly fixes their original shield's defect BUT criminals will often still be able to take the less valuable rear portion of the converter thus still putting you out of a car and awaiting replacement parts. Miller has a V2 of the shield that is redesigned and includes the deadbolt PLUS a piece that doesn't allow them to cut off the back easily but it is $330 and a few hours of work to install.
    I may add a locked tall fence to my carport if I keep the car to give me extra peace of mind but with the cage, and a lower deductible I feel better. If I was retired I would patrol my neighborhood at night with a few others and enact some revenge for all the BS I've gone through with this.
    But in terms of sales price, that will be my next step. I've heard CarMax and dealers aren't great options for selling. I'm not sure of Bluebook values exactly but think maybe around $7k for the 2004 and $13-16k??? for the 2013.
  9. Tombukt2
    13,405
    2,415
    Durham NC
    I do pay for some things because I simply don't want to take on the project or I'm busy but on the older cars the Gen 2004 to '09 should be a no-brainer to find folks to work on that aren't even hybrid mechanics because many of the things you're going to be doing to the Gen 2 now are basic mechanicals wheel bearings struts things of that nature The Gen 2 has a pretty solid setup and not all these bells and whistles and lights and nonsense that the Gen 3 went to and that's all cool but yeah if you're not comfortable contracting out work on a vehicle you own well I don't know maybe you're married and your partner can do it or I'm not sure what to tell you A lot of this stuff is pretty easy stuff and pretty easy to understand if you want to a lot of people don't have that desire. They're interested in pushing their papers at work and doing whatever they want after that me I don't like to leave a whole lot of things to other folks sometimes you have to leave some but I don't leave many I learned what I know by watching and learning I didn't go to engineering school spend a lot of time at tech schools I was poor so if I was going to ride it was going to be on my dime I didn't have a whole lot of people behind me to help me buy cars and do things every car I've ever owned I've kept for 300,000 miles even back in the '70s. Why because it's my money and I don't care about spending it to sit and step on a gas pedal most people are trying to get out of the car not live in it.
  10. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Maybe get rid of both and purchase a gas only car.
    Your mileage is low on both is why I say this. Also less of a cat theft target.
  11. rjparker
    rjparker Tu Humilde Sirviente
    10,503
    6,591
    Texas Hill Country
    I agree sell them both. Right now you'll get a premium for those cars especially the 2013 with low miles.
    At that point, buy a gen4 or a conventional Corolla, Camry or Civic.
  12. Samantha Los Angeles
    Los Angeles
    Yes, the Gen 2 might need something dealing with wheel struts though I'm not sure if I should trust this since the dealer has recommended lots of costly things in the past that others have said weren't really needed. A couple of quick questions for you since you know so much...is it time or mileage that would lead to a head gasket or engine replacement for the 2013? I'm also curious if it is best to go to the dealer for their inspection or find a good mechanic who can advise me?
    My father passed away a few years ago and I used to call him to ask about the various things but I don't have anyone now but I'm determined to keep a Prius because I love them and don't want the bastards and their theft to force me from my car.
    Tombukt2 likes this.
  13. rjparker
    10,503
    6,591
    Texas Hill Country
    Certainly by 175k a head gasket is likely. However that pattern emerged first from high mile per year drivers. Now that these cars are ten or more years old in many cases, we see 100k mile cars with bad head gaskets. So things like oil consumption, liquids pooling in the intake, thermal cycling and even carbon build up are likely contributors.
    Personally I think the only proactive measures are 5k oil changes, no long idling or excessive slow traffic and clean out the intake. Clean out the egr cooler if it codes but reducing blowby and oil consumption will reduce carbon early.
    Effective mitigation after the fact or with 100k miles before being proactive means a rebuilt engine with updated pistons, rings and intake manifold.
    Or trade the car which is the traditional and often smartest solution if you have the resources. Don't forget there are $2,500 brake boosters, $2,000 batteries and failing inverters waiting regardless of the engine health. Gen3 was a great experiment for Toyota engineers to determine how to make gen4 solid while still improving mpg over gen2.
  14. highmilesgarage
    highmilesgarage Active Member
    493
    182
    Kansas City
    honestly it's very rare to find honest dealership or shop. The dealership is the worst place to take recommendations that's why they're better called "stealerships". As the gen2 ages it will require some major maintenance and it could be big ticket items. Newer cars right now has tons of electronics that they fail first before the mechanicals and worst case is you have to go to the dealership for diagnostics since ordinary shops don't have the dealer level equipment to diagnose them. If you don't know of a shop that you personally know then it's better to sell both and just stick to ordinary Honda/Toyotas. If you're a DIY then a gen2 is a better option to keep.
  15. Tombukt2
    13,405
    2,415
    Durham NC
    Sounds like you've got it pretty well under control and you used to converse and have been taught by somebody that may have a good idea or had a good idea so I would say keep moving forward with what you're doing doesn't seem to be anything too out of the ordinary All I'm saying is the generation 2 is a little bit heavier duty car I'm not talking about how it looks just the car in general it's a little easier to keep running they're a lot more parts for it around and available just think of the little old ladies who have spent $3,000 having their brakes done just to get their rear bumper hit and now the car is total sitting down at LKQ with all those brand new parts on it this happens very regularly these cars are now getting totaled out for nothing just because of year of manufacture nothing else I regularly purchase complete cars that have had extensive maintenance been well taken care of now have a dent in the rear quarter panel and have been totaled and the people were silly enough to let the car go I would have driven the car with the small dent in the quarter panel personally I use in the service vehicles a 2004 to 9 car is not in your driveway to keep up with the Joneses. It's in your driveway because it's doing you a very good service not a dis service. The Gen 3 as you get to the mileage you're talking here You're going to have to be doing expensive services and that may be a disservice to your pocketbook That's all I'm saying now if you need a nice pretty car because you live in a certain place and other folks expect you to have that and your HOA deems that your 2004 to 9 generation 2 is an eyesore those are all problems that I really can't help you with those were other choices that were made The Gen 2 to me is the better of the two vehicles I own them both I drive my Gen 2 My Gen 3s women are driving them wives girlfriends daughters etc not me I just work on them. The funny thing I find is is I don't do much work on my generation 2 as the generation threes seem to require a need. I've been doing this with old Toyotas since about 1970 when the Corolla was just starting to get here the KE and the TE models which means nothing to people here.
  16. rjparker
    10,503
    6,591
    Texas Hill Country
    Dang... hope your wife doesn't read Priuschat.
  17. Tombukt2
    13,405
    2,415
    Durham NC
    They do not have no interest other than gas pedal pressing. You think I'm difficult. He he . You'd be inundated with newb shiet.
    Montgomery likes this.
  18. Samantha Los Angeles
    Los Angeles
    Thanks all! I appreciate your perspectives.
  19. Todd Bonzalez
    Todd Bonzalez Active Member
    250
    160
    Ireland
    Can you pass an inspection in California without an OEM or Magnaflow cat? Might be worth checking that before deciding to keep the 2013
  20. 2010moneypit?
    314
    122
    Beaumont ca
    If the smog technician is doing his/her job the car will fail without a CARB approved cat. Only OEM or Magnaflow. I believe these are the only two with carb numbers.
    Todd Bonzalez likes this.
