Semi Hub cap
Discussion in 'Gen 2 Prius Main Forum' started by omgitsroy326, Feb 17, 2008.
  1. omgitsroy326
    omgitsroy326 New Member
    267
    Los Angeles
    i have a non touring... and i have these partial hubcaps on my car.. what are they for ? i read it's for aerodynamics somewhere.. is this true?? cause it looks ugly as hell so i pulled 'em off.... it looks so much better now
  2. TonyPSchaefer
    14,816
    2,498
    66
    Far-North Chicagoland
    We can only assume that they are for aerodynamics; otherwise Toyota wouldn't have taken the time and effort to put them on. Since the main purpose of just about everything on the car is to reduce drag, improve aerodynamics, and increase mileage, there's got to be a reason for everything.
    But like all things, some people like them and some don't. I took mine off a couple years ago and have them hanging in my garage.
  3. omgitsroy326
    267
    Los Angeles
    hmm... well... if it only takes out 0.01mpg.. then it's coming off.....
  4. omgitsroy326
    267
    Los Angeles
    you know.. i don't think it's aerodynamics cause if it was.. then why not just produce 'em that way... whether metal or plastic .... should be about the same... unless you're considering the frictional surface...
    in other words.. my make it plastic / metal when they can produce it monolithically
  5. sugar land dave
    137
    houston
    I think it probably is just to protect the wheels from minor scrapes from curbs. Better to scratch an easily replaceable plastic ring than an expensive aluminum allow wheel.
    YOMV - your opinion may vary.
  6. omgitsroy326
    267
    Los Angeles
    toyota then assumes that all prius drivers can't drive :(
  7. Doc Willie
    1,717
    142
    Out there, somewhere
    No. Just a few.
    With lawyers.
