Sense lead connector to battery came loose, fixed but error lights persistent
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AmazonQueen78, Aug 15, 2018.
  1. AmazonQueen78
    AmazonQueen78 New Member
    United States
    HI all. Yesterday the wire leading into my sense lead connector in the battery came loose during a long road trip. I quick fixed it on the road, and today cut it loose and did a quality repair. The errors the car displayed when the breakage occurred remain lit. Should I give it a few days for them to go off on their own or do I need to do something to get them to go off. Pictures are of pertinent information. 2006 Prius..
    Thanks
    Alice
  2. JC91006
    16,493
    8,404
    Are you sure the warning lights are for the sense wire? Hopefully you read the codes that pointed you to that problem.
    You can clear most codes by disconnecting the 12v battery for about a minute. If it comes back, then you'll have to read the codes again.
