Sensor cover up?- newby question
Discussion in 'Gen 2 Prius Accessories & Modifications' started by Gaelyn37, May 21, 2007.
  1. Gaelyn37
    Gaelyn37 Gaelyn
    McMinnville, OR
    I just installed my velour dash cover in hopes of reducing the glare up in to the windshield. It does help. However, I've noticed that there are two circular spots in the dash up near the front left driver's side right near the windshield. They get covered up by the dash cover. Since there were no cutouts in the cover, I wanted to verify that these circles were not some important sensors that should not be covered up. I have not noticed any driving problems, so maybe they are insignificant?
    Any ideas will be appreciated.
    Thanks
    Gaelyn
  2. narf
    narf Active Member
    611
    44
    Colorado
    Four Touring
    unless you have a Canadian car only one of them is used, the other is a blank. In US cars the sensor is a Solar radiation sensor that is part of the automatic air conditioning system. I'd expect that covering it will prevent the AC from knowing when the car is in bright sunlight, so the AC won't adjust for it.
    In Canadian cars the second sensor is for the automatic headlight system that switches between DRLs and headlights.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    <div class='quotetop'>QUOTE(narf @ May 21 2007, 04:41 PM) [snapback]446904[/snapback]</div>
    Correct. Don't cover them.
    Tom
