Service Engine PO0607
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by bnaccs, Apr 20, 2015.
  1. bnaccs
    bnaccs bnaccs
    191
    Colorado
    My 2010 Prius with 66,300 miles had the service engine or check engine light come on for the first time. I took it to AutoZone and it was code po0607. I drove about 40 miles and it went off. Any ideas and should i take it in? The car is running the same.
  2. JC91006
    16,827
    8,600
    this could be caused by a weak battery, is your 12v battery original? Have you done the inverter recall?
  3. bnaccs
    bnaccs bnaccs
    191
    Colorado
    Did the inverter recall, and the original 12 volt. The car also sat outside in the cold for two days. How do I know if I need a new 12 volt, any signs?
  4. JC91006
    16,827
    8,600
    Since the battery is 5 years old, you should just go replace it. Then see if the symptom goes away. The battery will cost about $200 at the Toyota parts counter, for them to install it, it'll be around $300
  5. bnaccs
    bnaccs bnaccs
    191
    Colorado
    How hard is it to install it?
  6. JC91006
    16,827
    8,600
    If you have a 10 mm wrench, it'll only take you 15 - 30 minutes......quite easy.
  7. bnaccs
    bnaccs bnaccs
    191
    Colorado
  8. Mendel Leisk
    41,901
    Check the voltage with a multimeter. 12.6 volts or higher is a battery in good shape. 12.4~12.5 is a "middle aged" battery, still serviceable, but you want to monitor. 12.3 (or lower) is not so good, best to start shopping.
  9. lar.smith42
    lar.smith42 Active Member
    203
    118
    Double Oak , Texas
    Just had mine replaced at Lewisville Toyota Here in Lewisville Texas for $229.00
  10. bisco
    52,390
    great price.(y)
