Service price survey
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bluegrassman, Jan 27, 2017.
  1. Bluegrassman
    Bluegrassman Active Member
    229
    185
    US
    Just curious what other dealerships charge. My local dealer charges:
    Oil and filter change only, $65.00
    Tire rotation (no balance) $20.00
    Spark plug change $308.00
    #1 Bluegrassman, Jan 27, 2017
  2. Bluegrassman
    229
    185
    US
    By contrast, I found that another dealer less than an hour away only charges $45 for the oil change and $245 for the tune up, PCV replacement and ICE filter replacement.
    49,492
    just paid $106. for oil, tyres and 35 point inspection, including fluid top ups.
    Bluegrassman likes this.
  4. ddiamondd
    ddiamondd Junior Member
    34
    Colorado
    The dealer I go to offers a 3-pack of synthetic oil changes, tire rotations, and multipoint inspections for $150. Pretty good deal. Although, I just dropped it off this morning and they asked if I wanted to do the 90k service for $850!?!?! I almost laughed in their face, but politely declined.
    Rebound and Bluegrassman like this.
  5. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    Hmm I did the multipoint insepction, tire rotation with oil-change (synt) and 79.99+ tax final price paid 87.10 and they I got the state inspection as a comp (around $37 ...) NYC Metro Area
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Oil and filter change only, $56.00 synthetic
    Tire rotation (no balance) $15.00
  7. Mendel Leisk
    38,727
    Just looking through the US booklet, I see the major items it entails:
    1. Engine Oil and Filter change
    2. Replace Engine Air Filter
    3. Replace Cabin Air Filter
    4. Rotate Tires
    5. Major Brake Inspection
    I'd say $650 would be reasonable for that. I'd waive the two air filter changes, just check them yourself, knock off say $100.
  8. eliteconcept
    eliteconcept 700 mile club, top tank mpg 69.5
    449
    186
    Indiana
    2022 Prius Prime
    Even at 650 I'd still have a problem with that, at least without known what exactly "Major Brake Inspection" entails. The other services oil change and tire rotation normally are had for less than or around $100....so $550 or more for "Major brake inspection" is too much, assuming this is only an inspection and does exactly that just inspects and doesn't do anything tangible to the brake system
  9. Mendel Leisk
    38,727
    Pull off caliper, clean and relube contact points (piston face and "fingers" on opposite side)
    Pull off clean, relube and reinstall pins
    Remove, inspect, clean, relube and reinstall pads and shims
    Check rotor thickness against spec with micrometer
    Check rotor runout with dial gauge
    Possible clean up of rotor, depending on condition
