  1. florence french
    florence french New Member
    I am getting really bad mileage and the dealership told me it is because I need a fuel injection cleaning and a belt replaced, $350.00 total of work. Does this sound reasonable and if not does anyoneknow if a good service place in Boca Raton FL or how I can get a coupon discount for the Deerfield Beach dealership?
    49,694
    no, it does not. what was your mileage and what is it now? how many miles on your car?
  3. ZPriusv5
    ZPriusv5 Junior Member
    74
    Cincinnati, Ohio
    If you are a Costco member check out Costcoauto.com. You can get a service coupon to a participating Toyota dealer if there is one nearby.
  4. florence french
    I started with 11,00 miles and am now at 60,000, I have had the car for about 10 months
  5. rjparker
    rjparker Tu Humilde Sirviente
    8,102
    4,806
    Texas Hill Country
    What is the "really bad mileage"? Started with 11k and now 60k in 10 months? 50k miles in 10 months?
  6. florence french
    I fill up my tank on a Friday, drive to and from Fort Lauderdale three days a week and bu Tuesday I am on E
  7. rjparker
    8,102
    4,806
    Texas Hill Country
    Is this a joke? What miles per gallon (mpg) does your car indicate on the dash? Use the "Trip" button on the steering wheel. You get several, I use Trip B and reset the mileage calculation on B by pressing the button until it clears when I fill up.
    The manual way (non-automated) is to record the miles on the car at fillup, record miles when you fillup again, take the difference (say 45o miles) and divide by gallons bought (fill it to the top). If you bought 10 gallons, it would be 450/10=45 mpg
  8. florence french
    No joke at all. When I first bought the car I was getting 500 miles to the gallon, now I get under 400.
  9. rjparker
    8,102
    4,806
    Texas Hill Country
    I will buy your car. 400 miles per gallon is great.
  10. florence french
    LOL, 500 was better.
  11. RD_CDN_newbie
    RD_CDN_newbie Junior Member
    17
    Edmonton
    You must be talking miles about a full tank.
  12. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    Florence,
    Try the Gen II forum. Owners of the same vintage car may have experienced the same problem and have a solution for you.
    It could be your 12V battery going bad. From what I read on the Gen II ('04-'09) and Gen III ('10 and on), the computer will run the engine more often to keep recharging your 12V battery. That typically explains a loss of mpg's on the older cars (or so they say).
    It could also be the traction (hybrid) battery going bad. I would think that the hybrid system in your car is still under warranty.
    I would take it to another dealer and get a second opinion.
  13. Paradox
    29,110
    8,590
    201
    2014 Prius v wagon
    Another thread moved to the appropriate Gen II forum out of the Prius v forum.
  14. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    With it being an '08, I am surprised nobody suggested checking the +12 battery. It's about time for that thing to fal. there are about a million posts on this subject. What is the +12 battery voltage when the car is off? If it's less than 10.5, time for an Optima Yellowtop!
    I also agree, try another dealer, ask the same questions, see what they say!
  15. HaroldW
    HaroldW Active Member
    716
    95
    Grand Forks BC Canada
    Did you install new tire in last mth. or so? H
  16. skwcrj
    skwcrj Member
    278
    68
    Gig Harbor, WA
    I did on the second paragraph.... But that's ok. I'm used to it. My wife doesn't listen to me either. :p
  17. bisco
    49,694
    when i get to 400 miles per gallon, i'm not changing anything, rolling with it.:p
  18. EffinRed
    EffinRed Junior Member
    32
    Boston, MA
    Like others have mentioned, check the 12v battery. A question to the group: if the OP is on the highway most of the time, would you suspect alignment issues as well?
  19. Mike Mc
    Mike Mc '16 Prius 4, '13 Prius 3
    88
    35
    Fort Worth
    The problem is either new brakes, new tires an old 12v battery. It could be that he is driving on the hwy so much...166 miles a day average every day for 10 months.
  20. Stephenjn
    Stephenjn New Member
    Boise, Idaho
    New member here, and apparently I posted in the wrong forum. How do I move a thread to the proper forum?
