Set Nav Screen to Always Be In Night Mode ?
Discussion in 'Gen 3 Prius Audio and Electronics' started by going red baby!, Dec 8, 2009.
  1. going red baby!
    going red baby! still a n00b
    610
    96
    Los Angeles
    Is there a way to set the Nav screen to always be in night mode? I like it a lot better.
    I see on pg.32 of my Nav manual it says how to have it change when the lights are turned on but I'm wondering if anyone knows a way to have night screen on all the time (without turning on lights although I suppose that would be a workaround).
    Thanks.
  2. kamick81
    kamick81 Junior Member
    60
    Auburn, AL
    Only way to do it without hacking into your wiring harness would be to run with the head lights on all the time. :)
  3. Tideland Prius
    16,195
    Play with the screen brightness?
    Or do you just prefer the black background as opposed to the white?
  4. going red baby!
    610
    96
    Los Angeles
    I prefer the black background. But since I rarely use the Nav I just started leaving the screen in audio mode and that works for me. :)
  5. go83
    go83 New Member
    LA
    The day mode button shown on page 32 doesn't exist on my screen; why is that???
  6. Tideland Prius
    16,195
    You need to have the headlights on first.
  7. rdahlke
    rdahlke New Member
    Also if you have your dashboard lights all the way up the button is not there. The dial is down by your left knee and there is a notch you turn it past to set the lights at their highest.
  8. Bobsprius
    Bobsprius BobPrius
    679
    Buffalo
    Going Red....
    Try hitting the DISP button on the bottom right side of your NAV screen (external) and then adjust the brightness accordingly....;)
  9. going red baby!
    610
    96
    Los Angeles
    Thanks but adjusting the brightness doesn't do it, you still have a white screen even if you dim it down. I would like it to be black all the time like it is when the lights are on, but I just leave it in audio mode and that works okay.
