SF Bay area: PG&E do I need to get into a different rate plan?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Sanjath, Nov 3, 2012.
  1. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    I assume that PG&E's rate plan change is required for the pure electric car, is there any this need to be done for PiP?
    Haven't checked the bill, but I am guessing if I charge early morning between 3 am and 6 am, it should be good. Right?
  2. Rebound
    Rebound Senior Member
    3,995
    2,643
    Portland, OR
    Not all PG&E plans are time of use. You need to look at your existing bill and calculate how an additional 100 kWh will affect it.
    Gas is sold in gallons and electricity is sold by the kWh. The rate per kWh increases as your consumption increases, unless you're on a time of use plan. If you own an all-electric, you definitely want time of use, but since your Prius only uses about 100 kWh per month, it's not so critical, although you'll probably save money.
    To be more specific than that, we'd need your zip code and an idea of how much you pay a month for electricity, and ideally your consumption in kWh.
    Hi Burrito! likes this.
  3. lensovet
    2,615
    496
    Burlington, NJ
    Just to add: no rate plan change is ever "required"; it might simply make economic sense.
    There are also two separate issues: whether you have a separate meter, and what sort of rate plan you have.
    To sign up for the EV rate plan, you need to install a separate meter. This makes essentially zero financial sense for the PiP.
    You can also just change to a time-of-use plan for your entire house. Note that depending on your electricity consumption patterns, this might result in higher costs for you than if you keep your current plan if you use a lot of energy during peak hours.
  4. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Thanks, checked the bill, looks like I use around 320 kwh of baseline @ 0.13/kwh and use around 70 more at 0.15/kwh. Probably I am going to pay around 0.15 for the extra 30 of the 100 and last 70 at $0.30.
    According to the pg&e spreadsheet, 101-130% of baseline usage goes to second tier pricing and then it doubles for the third tier!
  5. lensovet
    2,615
    496
    Burlington, NJ
    if you go into your online account management, you can see whether a time of use rate plan will save you money or cost you more based on your past usage. that should be a good start.
  6. lensovet
    2,615
    496
    Burlington, NJ
    which apparently you can't do right now because it's under maintenance
  7. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Did some more research, looks like my rate schedule is E1-XB. For that in winter(starting nov 1st) the baseline usage goes up from 11 kwh to 11.7 kwh per day. So, so hopefully I can cover 30% of the pip charge in first two tiers, I guess I would still pay 30-40 kwh in third tier.
  8. cwerdna
    cwerdna Senior Member
    12,544
    2,124
    SF Bay Area, CA
    That's not your rate schedule. That's related to Understanding Baseline Quantities. Schedules for residential have names like E-1, E-6, E-9A, etc. Select a Rate Option has summary, but they can be way complicated, esp. if you switch to a TOU plan.
  9. SJ PiP
    SJ PiP Member
    190
    35
    check out
    Plug-In Electric Vehicles
    i called the phone # on this page (not the usual PGE customer service) and the operator ran a usage analysis which showed i would save more on E-9A over E-1 ("A" doesn't require any hardware changes to smart meter). Still waiting for connect E-9A to take effect.
  10. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Yeah, actually I omitted the E1, fixed it. Rate schedule is E1-XB, where E1 specifies the residential rates, XB specifies the baseline usage watts allowed.
  11. CharlesH
    2,796
    1,163
    Roseville, CA
    The E-9A rate is working fine for me. But they are planning to remove that rate soon in favor of a non-tiered TOU plan for EV owners, and I have no how idea how that would work out.
  12. SJ PiP
    SJ PiP Member
    190
    35
    hi pge folks, after reading up on pge website, is it correct that for TOU plans, each period (Peak, Part Peak, and Off Peak) has its own Baseline (kwh) per day?
    for example, if 11kwh is the summer baseline, and summer Peak is 2-9pm, then the Summer Peak baseline is 11kwh * 7 hours / 24 hours =3.2 hrs per day (actually weekday Mon-Fri). so, any amount over 3.2 hours is charged at next higher tier rates (either 2,3,4,5 depending on how much higher than 3.2?)
  13. CharlesH
    2,796
    1,163
    Roseville, CA
    As I read the definition of the E9 rate plan, you distribute your total baseline over the three time rates (Peak, Part-Peak, Off-Peak) proportional to the number of kwh you used in each of the three rates, not the number hours the rates are in effect. So if you used 50 Peak kwh, 100 Part-Peak kwh, and 150 Off-Peak kwh, your Peak baseline would be (50/(50+100+150)) = 1/6 of your baseline, your Part-Peak baseline would be 1/3 of your baseline, and your Off-Peak baseline would be 1/2 of your total baseline.
    This complicated stuff is one reason they are moving to a new TOU rate plan which is not tiered.
    SJ PiP and lensovet like this.
  14. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    According to PG&E site, it says my best rate is with the E6 TOU plan. Interestingly, it analyzes each and every bill for last 12 months and shows that I could've saved $80 over 1 year if I had E6 plan. I did not have EV for all those months. Looks like I would've benefited by using TOU plan all the while. So, may be worthwhile to check their site again next month to see with EV how it would change. One thing though is it doesn't even suggest the E9 plan at this time.
    Only now did I go through their site and saw that they provide quite a detailed reports. Good job PG&E!
    lensovet likes this.
  15. SJ PiP
    SJ PiP Member
    190
    35
    the PGE site doesn't show you the EV rate plans by default. here's PGE's special page for EVs which lists a special phone number to call about EV rate plans. i called the number and had them run an E6 vs. E9a analysis and the latter came out lower so i switched. note: for some reason E9a pricing data does not show up on the My Usage page (but works fine for E-1 and E-6)
    PEV Calcluator
  16. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Thanks, I went through that, one thing though is it doesn't analyze our usage. Instead, it is an approximate charges. Where as their page for rates (Pacific Gas and Electric Company) actually analyzes my own bill with different plans month by month.
  17. SJ PiP
    SJ PiP Member
    190
    35
    true, but as you saw PGE omits the E-9a on that page. that's why i had to call PGE directly to do it (make sure you specifically ask about EV rate plans )
    Sanjath likes this.
  18. ronlprius2
    ronlprius2 Junior Member
    56
    San Francisco
    I added solar before I bought my plugin and my electric bill went from $150 to $15 per month. At the same time I changed to time of use. I don't even notice charging my car.
    iPad ? HD
    Sanjath likes this.
  19. Sanjath
    Sanjath Member
    107
    23
    SF Bay Area
    Currently my electricity bill is $50, I expect it to go up by $20 (may be $30 max). So, not sure if putting solar is worth the investment. I use only one charge per day (may be bit more on the weekends). I am guessing it would cost me at least 10k to put in a solar system.
  20. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    We are in the same boat. My monthly electricity cost is about $60 on average. Prior to getting a PiP, I called 2 solar panel installers to give me a quote. One company over the telephone said, I would never make back the cost of the solar panels and wouldn't come out to quote me. They recommended a bare minimum of $100 a month electricity bill and even then, you just break even. The second company was a solar lease company and they came out and said the solar lease was some $100 a month to them and then $15 to the power company. Again, I'd lose money. Don't get me wrong, I'm willing to pay extra to be green, I bough t the PiP after all . But two times my electricity bill is too high of a cost. I'm better off buying LED light bulbs and energy efficient appliances.
    Anyway, after some 11 days of charging the PiP, my first's month's electricity bill went up to $73. Adjust for colder weather and wave of the hand, it's a less than a buck a day. We'll see what next month brings when most of my PiP charging lands in Tier 3.
