shaking 47-53ish mph
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by username101, Jan 23, 2016.
  1. username101
    username101 New Member
    ft collins, colorado
    my 07 prius with 190k started shaking violently when going down hill if i press the gas or brake at all is goes a way suddenly, this happens only around the high 40's to low 50 mph range and once at 75, this happened just after my tires where balanced and rotated brought it back they re balanced them and said they balanced out perfictly and the problem still protested. i drive on dirt roads all the time and i hit a big pot hole earlier last spring but the issue JUST started after the balance a week ago,I'm at a loss here this is my first car and i don't really know much about them, any help would be appreciated!
  2. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    IF your tires are balanced as you reported the likely cause is possibly front end bearings going out. Now I am not going to just point that out as the ONLY possible but the deal is that a front end inspection is necessary to find out which components may be worn and loose. This is noto to say your alignment needs to be checked as well. Many times when you get the shakes your wheels start to occillate and a small tap of the brakes stops them from continuing. Now another issue is even though your tires are balanced the run out on the rims is another factor to check. In thinking back to your original complaint - I think that one of your rims has too much runout and now is in the front instead of in the back as before. Remember none of this happen before your rotate and rebalance work. I would get the tires back to their original positions in hind sight and go from there. Sorry I should have written this portion first but I was rethinking the problem as we go and see that putting the tires back to where they were is the logical thing to do.
    51,679
    welcome! did you have them dynamically balanced?
    edthefox5 likes this.
  4. Lucifer
    Lucifer Senior Member
    1,014
    486
    Nh
    First, check the lug nuts, then take it to the dealer and have them do a road test, bearings don't shake a car, they make it disturbingly loud to drive it, increasing in volume with speed. Lots of frozen snow and mud on the wheels would have a shaking effect.
  5. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    So your saying one tap of the brakes and it stops all that you described in one instant?
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,833
    Clearwater, Florida
    Like Bisco said how did you have them balanced? Any issues with tires have them Roadforce balanced which means there balanced on the car instead of on a balancer. The difference is the tire is rotating during balancing and they can measure run out.
    Thats a bent wheel to you. Sounds like maybe a warped brake rotor. Especially if you don't use B mode and ride the brakes down mountains alot. That heats the crap out of the brakes and rotor. The rotor will be red hot. Ever smell anything burning after a mountain run?
    After a down hill run on big mountain pull over and feel the front wheels. Be careful they may be really hot. The brakes are pretty bad on this car. Next time your on the highway at 60 mph's and no one is behind you put the car in neutral and try to stop without regen.
    No regen just plain old brakes. Scary.
  7. goldfinger
    goldfinger Active Member
    535
    403
    Buffalo
    Could be a combination of things including rear bushings. I would take it to a good tire shop that also does alignments and related repairs.
  8. username101
    i jacked up the car and it turns out to be a really broken uper tirod on the drives side and a slightly warn out one on the passengers side had les shawb do both for 300$ thanks for all the help!
  9. bisco
    51,679
    wow, hard to believe they could miss all that when doing the tyres.
  10. Montgomery
    Montgomery Senior Member
    2,254
    2,241
    Orange County, CA
    One can never tell these days. Any issue with my Prius and I am going in here first. The knowledge and car experience is just the best!
  11. Dion Kraft
    Dion Kraft Member
    304
    92
    Washington, UT
    Good you found the problem. In the future because you drive on gravel roads it puts more stress on parts which were really not designed for that kind of service as a regular event. Also in light of that you will experience more wear on your front end parts like bushings as well..
    You can minimize those wear concerns by driving slower as then the forces are less but still could make your wear longevity longer.
    If you were driving a 4x4 truck I would not be typing this but with cars they are more fragile. But in any event your concerns are now in the repair/completion stage. Good Luck.
  12. edthefox5
    10,096
    4,833
    Clearwater, Florida
    Broken tie rod you can't drive the car. Its what steers the wheel. I think you got rumped pretty hard there.
  13. goldfinger
    535
    403
    Buffalo
    Well he does drive on dirt roads all the time. Maybe you can drive with one wheel pointed wherever it wants to go. My wife can drive on a flat tire and not know it and she grew up on a dirt road.
  14. edthefox5
    10,096
    4,833
    Clearwater, Florida
    lol ....you got me there with the wife thing...I'm happy if the car's not on fire when she comes home...
