Sharing outlet with Garage Door Opener
Discussion in 'Prime Plug-in Charging' started by Robert N Lute, Jul 1, 2019.
  1. Robert N Lute
    Robert N Lute Junior Member
    Denver, CO
    2019 Prius Prime
    Ok here is the deal. We live in an apartment complex and we do have a single car garage assigned to us. The only outlet in there is currently has a garage door opener plugged into it. This does appear to be just a standard 110 outlet box. My wife got permission from the apartment complex to use the outlet to charge the prius using the 110v cable.
    Here is my concern. Is it ok to share an outlet/circuit between them? I might have the car charging while the door opens.
  2. john1701a
    john1701a Prius Guru
    12,797
    5,280
    57
    Mine shared a line with the freezer. It was no big deal.
    You want certainty, just buy a Kill-A-Watt meter for $15. That will show you the draw from the opener won't be a concern.
    jerrymildred likes this.
  3. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,799
    2017 Prius c
    Should NOT be a problem........unless maybe it is a really HEAVY door with an industrial opener on it.
    BUT.....it might be a good idea to be prepared.....by finding out where the breaker is located.
    51,155
    no problem at all. worst you can do is blow the breaker. and don't forget, you have an 8 amp option
  5. Robert N Lute
    Denver, CO
    2019 Prius Prime
    An 8amp option? I did not know that. Where is that setting?
    OMG thank you so much. I just found a video showing where that setting is and that will work perfectly.
    Arctic_White and bisco like this.
  6. bisco
    51,155
    it should be in the menu
  7. john1701a
    12,797
    5,280
    57
    Look for this...
  8. noonm
    noonm Senior Member
    575
    595
    2018 Prius Prime
    Easiest solution is to test it out.
    First thing is to check the outlet. Make sure that it looks in good condition, with no noticeable damage or rust. I'd also recommend picking up an outlet/GFCI tester (Amazon.com: Receptable Tester) and check the outlet. I do it to every place I live in and you'd be surprised how often I find miswired/poorly wired outlets.
    After that, locate the breaker box, plug the Prime at max current, and open and close the door a few times. Breaker popping should be pretty noticeable. If you see/hear/smell something off, you can run to the breaker and flip the circuit off manually.
    Another good check is to confirm what is and isn't on the same circuit. Turn the circuit off at the breaker box and then go around your garage/adjacent rooms and check each switch and outlet. If you find another outlet/switch connected to the same circuit, either repeat the above test with the additional items on the circuit or ensure that you don't put any heavy loads on those outlets/switches. Some child-proof outlet plug covers would do the trick nicely.
    And welcome to the Prime family!
  9. m8547
    m8547 Senior Member
    946
    626
    Colorado
    2018 Prius Prime
    If it's a NEMA 5-20R receptacle (20A, T-shaped neutral socket) then it's probably a 20A circuit (unless it was incorrectly wired) and it's almost certainly fine to charge at 12A on the same circuit unless it's a large industrial garage opener. Commercial buildings are often wired with 20A circuits instead of 15A, so there's a good chance you'll find one in an apartment building.
    If it's NEMA 5-15R then that's inconclusive since it could be a 15A or 20A circuit.
    Arctic_White likes this.
  10. Salamander_King
    Salamander_King Senior Member
    11,009
    8,935
    New England
    If only other thing on the circuit is a garage door opener, you should be fine even with 15A circuit. The question is, how difficult is it for you to check to see if anything else is on the same circuit? Just because one outlet in the single car garage has only a garage door opener plugged in does not mean there are other outlets outside of the garage that is on the same circuit. If you have an access to the breaker box, you can just test to see if it can handle the charging.
    Linda Ackley likes this.
