Shattered Sunroof Wind Deflector
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by KBee, May 9, 2015.
  1. KBee
    KBee Junior Member
    29
    Today I noticed that my sunroof wind deflector is shattered. It is the front glass panel that angles up when you open the sunroof. Has anyone had is happen to them? How much did cost to repair it and did you have the dealer do it?
    51,154
    i think i do recall someone else mentioning it. forget the cost though, $300.?
  3. KBee
    KBee Junior Member
    29
    Does anyone have any advice on whether I should have an auto body shop do the repairs vs the Toyota dealership?
    51,154
    glass shoppe?
  5. royrose
    royrose Senior Member
    1,389
    953
    Foot of Pikes Peak
    I had a scion TC with a similar sunroof. The deflector glass shattered twice (once from a falling tree branch). I do think it was around $300 installed. The installation is pretty simple. You could probably do it yourself but you will have to order the glass from a Toyota dealer (or OEM supplier) or see if a junk yard has a used one. Toyota paid half the cost of the second replacement which happened soon after the first one.
    Toyota issued a recall because of broken pieces coming into the TC. The fix was to put an adhesive clear plastic film on the inner surface which didn't actually prevent shattering but prevented any broken pieces of glass from coming into the car or flying into the air.
    Here is a link to info about the recall: Scion Recall 05V483000: Oct 27, 2006
