She Likes to Drink-Should I Get Rid of Her?
Discussion in 'Gen 3 Prius Main Forum' started by Borninblue, Feb 14, 2020.
  1. Borninblue
    Borninblue Active Member
    233
    158
    Cleveland, Ohio
    My 2010 with about 135K on her is starting to drink more and more. Dealer recommended, and I switched to 5w20. This did about nothing, consumption is probably 1qt every 1,500.
    EGR, manifold, throttle body cleaned including cooler, all fluids changed, breaks completely done, plugs etc done when I bought her at 114K. Been almost 2 years and debating on the future. Do I cut bait and trade in on a Prime or ride it till it dies.
    I would be more inclined to ride till she dies with the exception of two things. The big battery will need replaced probably within a year or two. Dr. Prius says I’m between 40% and 50% life the few times I’ve tested it.
    I really don’t know how long the engine will last as an oil burner? I need to install a catch can, whichI haven’t got to yet. Bought her for about $5,400. I’m more intrigued with the Primes the more I read and watch videos. I can almost make a complete trip to and from work with the electric mileage rating.
  2. Leadfoot J. McCoalroller
    8,067
    7,548
    Pennsylvania
    2018 Prius c
    Most new car dealers are offering pretty easy terms lately. Worth looking at some numbers. Also sounds like you've got a pretty good use for one.
    Borninblue likes this.
  3. Borninblue
    233
    158
    Cleveland, Ohio
    I’m also wondering if they will devalue my trade since I told them at the dealer it was burning oil. Probably noted the switch to thicker oil in records.
  4. dubit
    dubit Senior Member
    850
    538
    23
    Indiana
    2016 Prius c
    Possible, but doubtful. Sales generally doesn't look at the history, unless it's an out of the ordinary low mileage unit for it's age. But why not keep it till it dies. Heck a brand new Honda can burn a quart every 1000 miles and that's within tolerance. Like Coalroaller said though, might not hurt to look at some numbers.
  5. Prodigyplace
    12,526
    11,747
    Central Virginia
    I thought somebody was asking about getting rid of their drunken valentine :eek::confused::oops:
  6. Tande
    Tande Active Member
    537
    321
    Mich.
    This may be worth a try? .......just saying
    SFO, Borninblue and Aaron Vitolins like this.
  7. Aaron Vitolins
    Aaron Vitolins Senior Member
    1,612
    1,144
    Franklin TN
    I know some members have used a 1 qt of Marvels mystery oil with their oil change, run it a few thousand miles and changed it with fresh oil and had fairly good luck with that.
    could be worth a shot? I personally have used it for maintenance purposes before, and use it in my gas tank with good luck.
    ASRDogman and Borninblue like this.
  8. Mendel Leisk
    41,295
    New short block?
  9. Raytheeagle
    Raytheeagle Senior Member
    11,265
    15,520
    Bay Area, California
    2019 Prius Prime
    I used the following to help with oil consumption:
    • BG Products EPR
    • BG Products Extended Life MOA
    • 0w-40 oil
    Our old 2010 consumed a quart every 4-5k miles and it maintained there.
    One thing I noticed is that if I traveled above 65-70 mph, the oil consumption would rise significantly.
    Good luck and keep us posted (y).
    #9 Raytheeagle, Feb 15, 2020
    mikey_t, mjoo, m.wynn and 1 other person like this.
  10. Borninblue
    233
    158
    Cleveland, Ohio
  11. Borninblue
    233
    158
    Cleveland, Ohio
    Funny you say that. I noticed the exact same thing. If I travel above 70 she burns more. Few days I went above 80 and I could tell the burning increased even more.
    Raytheeagle likes this.
  12. Mendel Leisk
    41,295
    So it's not just that you're not doing less electric-mode: ceiling for that is something like 45 mph. Too, I would think the difference in oil consumption between 70 and 80 is rpm related.
    mikey_t likes this.
  13. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,801
    2017 Prius c
    The change in oil you make isn't REALLY that much different.
    Before you junk it only because of oil consumption, try changing to a "high mileage" oil.
    They are usually something like 10W30 or 10W40 with special additives.
    And yes, that weight oil will work just fine.
    Any improvement will be temporary; how long.....nobody knows for sure.
    And if there is an actual oil leak that you haven't noticed, the different oil probably won't help at all.
  14. sam spade 2
    7,035
    2,801
    2017 Prius c
    If and only IF the oil loss is due to stuck or gunked up rings.
    If it is due to plain old wear, it can actually make matters worse while the MMO is in there.
  15. Aaron Vitolins
    1,612
    1,144
    Franklin TN
    At 135k I would find it very hard to believe it’s worn out
  16. Prodigyplace
    12,526
    11,747
    Central Virginia
    A used car dealer I pass regularly gas a Gen 3 with 300K miles for $5000.
  17. Borninblue
    233
    158
    Cleveland, Ohio
    300K for $5,000?! Come on now that’s robbery! Probably never even had the EGR cleaned!!! 5K for ticking time bomb wow
    Prodigyplace likes this.
  18. ETC(SS)
    7,131
    If you’re going to dump her for a younger, prettier model, it’s gonna cost you.
    Me? I’d wait until the traction battery goes Tango-Uniform and then kick her to the curb.
    With your renewed interest in things like OCCs and engine parts cleanliness this car probably has at least 50,000 miles left in her.
    50,000 miles on a $25,000 Prime will depreciate it FAR more than what it would cost you just rekindle the romance with the car that you already have.
    For JUST the increase in tags and insurance for two years you could probably get a remanufactured battery.
    If you’re going to start seeing other cars, wait till later in the year before you take one home.
    Tax time.
    EVERYBODY is wanting to spend now.....
    dubit and Borninblue like this.
  19. mjoo
    mjoo Senior Member
    1,155
    1,326
    Michigan
    I'd clean the PCV valve and install an oil catch can.
    Pixel XL ?
  20. Borninblue
    233
    158
    Cleveland, Ohio
    Good advice thank you....dealers will be more thirsty later in year. Plus that RAV4 Prime coming out looks delicious....I need the AWD, although the blizzaks make the Pri a little tank I must say. I just love that center stack in the Pri Prime though.
