Shell Gas with Nitrogen Enrichment
Discussion in 'Gen 2 Prius Main Forum' started by McShemp, Jun 15, 2009.
  1. McShemp
    McShemp New Member
    371
    SA, TX
    Anyone see any FE changes using the new Shell gas? I've had someone tell me it killed their MPGs, but there's too much variability in daily driving over a single tank for me to believe in it.
  2. ibmindless
    ibmindless Member
    206
    OH! Maybe that's it! I noticed a significant MPG loss about a month ago and couldn't overcome it. I finally changed my tire pressures from 40/38 PSI to 45/43 PSI. I regained a couple of MPG almost bringing me back to previous FE. I only burn Shell. I thought it may have been a summer reformulation of the gas. So, what's the change they made and their rationale?
  3. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    My last tank was disappointingly low. This included a trip to NY & short hop commuting in the summer heat. I'll have to buy gas within the next two days and expect a very high tank. Normal commuting & cooler than average temps. I suspect only a marketing effect.
  4. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
    You know, maybe this will rock the boat here, but I have actually noticed a 2 mpg positive difference so far. I have used Shell for 25 years, just because the station is down the street, and I have the gas rebate card I can stick in a pump, pump, and run!!!
    Normally I have a large hill I have to drive up and down every day I go to work. I usually get 400 miles for 8 gal. of gas. This last tank, I am at 420 and just getting to the 2 pip mark, which is the spot I choose to refill every time.
    My routine does not vary, same mileage every day, same hill, up and down. The only variable here is me, maybe I am having a rather good Hypermileing month, but what ever the case I am getting better mileage!
    Go figure.
    On a positive note...♦
    I do like the Shell Card gas rebate!!!
  5. Qlara
    Qlara New Member
    488
    My Prius also burns Shell (Regular) solely since day 1, its MPG is only creeping up by my improving of Hybrid driving-skills. But it's started out above 50+mpg at the beginning anyway.
  6. McShemp
    McShemp New Member
    371
    SA, TX
    I can't make a judgment on the new Shell formulation yet, but I wanted to ask others what they experienced. My normal driving routine is off due to sharing driving duties with my wife. Her Prius is being repaired after a nasty accident, and she's been driving my car as needed. We went a couple of weeks without a rental.
    Needless to say that her driving style is different from mine, and my FE is unreliable for my current tank.
  7. kenmce
    kenmce High Voltage Member
    1,531
    507
    NY
    Nitrogen is an inert gas. It does not burn, it won't help anything else burn. Why would anyone want it in gasoline?
  8. KK6PD
    4,003
    944
    118
    According to a Shell press release....[FONT=arial, helvetica, sans-serif]
    [/FONT]Shell has introduced Nitrogen Enriched Gasoline in all three grades. The new formulations contain a novel cleaning system designed to clean up gunky build-up on intake valves and fuel injectors.
    Gunk (carbon deposit) formation on injectors can reduce fuel flow and fuel economy. Gunk has a porous surface that can trap the gasoline that is sprayed by the fuel injector; as a result, the fuel charge does not get in the cylinder at the right time, thus negatively affecting combustion.
    Shell says that its Nitrogen Enriched Cleaning System contains a “carrier fluid” that acts like water, washing away both the cleaning agents and the engine gunk into the cylinder, where gunk is destroyed as part of the combustion process. In addition, The Nitrogen Enriched Cleaning System acts like a barrier to keep engines clean and protect them from performance-robbing gunk better than before.
    Nitrogen is a key element of the active cleaning molecule in the new fuel, making it significantly more stable at the higher temperatures common in modern engines, such as direct fuel-injection gasoline engines. The increased stability ensures that the molecule can work under much tougher engine conditions by resisting thermal breakdown better than conventional cleaning additives.
    Shell worked with automotive manufacturers to gain insight into current and future engine technologies. Nitrogen Enriched Gasolines were tested in laboratories, independent testing facilities, and on the road, accumulating more than a half-million miles in various vehicles and engines—including conventional, turbo-charged, and direct fuel-injection gasoline engines, hybrids, newer vehicles with low mileage, and older vehicles with high mileage.
    [​IMG] Shell dual-fuel testing. Click to enlarge. Shell scientists used dual fuel engines to conduct head-to-head comparisons with other lower-quality gasolines. In these tests, split engines simultaneously run on different types of gasoline in order to collect data under the exact same conditions. The results of these head-to-head comparisons showed that the Shell Nitrogen Enriched Gasolines are more effective than lower quality gasolines in protecting against the build-up of harmful engine gunk, according to Shell.
    The Nitrogen Enriched formula prevents build-up of gunk more effectively than gasolines containing only the minimum amount of cleaning agents as required by the EPA. The new cleaning system is certified to meet the Top Tier Detergent Gasoline Standard—voluntary standards designated by leading automakers (Audi, BMW, GM, Honda, Toyota, Volkswagen) to try to raise the bar on fuel quality beyond minimum government criteria.
    Shell V-Power premium gasoline provides maximum protection with the highest concentration of the Nitrogen Enriched cleaning system and more than five times the minimum amount of cleaning agents required by federal government standards.
    [FONT=arial, helvetica, sans-serif] I just feel cleaner already,
    Clean & Green.
    [/FONT]
