Shift Gear Lever light not working
Discussion in 'Prius c Main Forum' started by Prius_C14, Jul 11, 2016.
  1. Prius_C14
    Prius_C14 New Member
    San Gabriel Valley
    2014 Prius c
    Hi everyone!
    I have a 2014 prius C III and i've come to own it for 8 months now. The green light that was lighting up the Shift lever display isn't on anymore. Also, the whole display ( P,R,D,B) are not lighting up, but everything else is, like the EV mode and ECO button are. Does anyone know what is going on?
  2. xliderider
    xliderider Senior Member
    7,871
    3,116
    Honolulu, HI
    Have you checked your fuses? Look in your manual or the fuse cover for the location of your fuses labelled instrument cluster or dash, or something similar.
    Other than the lighting, is everything working?
  3. orenji
    orenji Senior Member
    5,884
    3,486
    You are under warranty, take it into the Toyota dealer and have them repair the issue.
  4. dick_larimore
    dick_larimore Member
    162
    70
    Central Indiana
    I think there is just a single bulb that lights up the gear positions, The stray light that you have seen on the shift lever is from that single bulb.
