shift to B mode for more regen under ~21mph
Discussion in 'Gen 2 Prius Main Forum' started by Flying White Dutchman, Aug 24, 2009.
  1. Flying White Dutchman
    4,376
    313
    whe all now that when you shift to B mode the ICE is used to have some extra brake force
    but when you brake and you go below ~21mph ( 35kmph ) and then shift to B mode there is NO ice turning and more braking from the electic motors.
    i am using this a lot more now to capture more regen and less friction brake's because even when braking slowly i still here the frictions bbrake's touch the disc.
    and with low speed B mode braking a dont use the brakes until a full stop.
    2 people like this.
  2. JimboK
    JimboK One owner, low mileage
    2,817
    188
    49
    Chesterfield, VA
    I often do the same thing. It makes it easy to control deceleration with just one pedal. My problem is sometimes forgetting to put it back in D for accelerating.
  3. spinkao
    spinkao New Member
    316
    78
    Czech Republic, EU
    Very interesting. I must try it.
  4. LRKingII
    LRKingII New Member
    679
    132
    Idaho
    Good info but i must say it was the title of this thread that grabbed my attention. :D
  5. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
  6. Mark57
    2,945
    2,738
    OK
    Ditto! ;) Got to love those occasional typos.
  7. TheForce
    3,461
    537
    Wheelersburg, Ohio
    I have been shifting to B for a while now. I use it to keep the car from losing regen when going over pot holes. If you go over a pot hole while riding the brake traction control wants to kick in and you lose the regen. If I use B below 20mph it usually wont lose any regen when going over the pot holes.
  8. JimboK
    2,817
    188
    49
    Chesterfield, VA
    Not sure how, but I missed the typo first time around. :rolleyes:
    Not always. At speeds below 20 MPH the ICE doesn't spin and the slowing effect is entirely from regen. So if there is a need to brake anyway, there is no waste of energy. From Hobbit's paper:
    Under 20 mph, if the engine is not already running and your foot comes
    off the accelerator, B mode simply regenerates reasonably heavily [30A or
    so] into the battery. This drops off around 12 mph to a lower current,
    and is then similar to being in D until regen capability kicks out entirely
    around 7 mph. So between 19 and maybe 10 miles per hour, you can use "B"
    to slow down in an energy-productive way
    , and essentially drive around in
    electric-only mode with one pedal ....
  9. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    I think you mis-interpret Hobbit's data. Your assertion is incorrect. Iff your in EV mode, B-gear below 31 KPH (~20 mph) will indeed cut off the ICE and increase regen when the brakes are not applied. Basically its a harder coasting decel. I have amp meters that will register this quite clearly.
    I don't think it does anything special with brake pedal regen though. You can get the same regen in D simply by applying more brake pedal pressure. The B-gear coasting decel is definitely smoother and fun to surprise tailgaters with (warning... no brake lights!).
    11011011
  10. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    This is the key paragraph. B mode doesn't allow for any more regeneration, unless perhaps at the very high end, but you can do it with one foot. Whether it's worth shifting for that "benefit" is a matter of personal preference.
    Tom
  11. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Not true. B does allow more regen on a coasting decel while the vehicle is in EV mode and the speed is below 20 mph.
    The OP is correct, your assertion that B doesn't allow for greater regen needs to be qualified by "B doesn't allow greater regen while significant brake pedal pressure is applied at speeds above 20 mph"
    Absolutes don't work with this axiom in in either case.
    11011011
  12. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    I think the gains doing this are miniscule. That said, I do it almost every day as I pull down my driveway and into my garage...here's why/how...
    1)I'm able to coast/glide the last 1/4 mile from the top of my road into my garage. I do this in a neutral glide. While in neutral glide I see about -1.7 amp draw, about an amp more with the headlights on.
    2)As I'm going down the last 50 yards or so to my garage and want to begin to slow I can go into D and allow it to regen brake which usually regens around +7 amps or so down to about 10mph where I start seeing negative amps (-1 to -3 or so). If, instead I go into B-mode I see slightly higher regen (but not much more), but the big difference is that I don't see any Negative amp until I get right to 7mph. So I gain slightly more regen for a slightly longer time.
    3)I bet it amounts to a grand total of about 10 feet of extra battery range, LOL, but it's all part of the "grab every little bit of energy I can" philosophy.
  13. Flying White Dutchman
    4,376
    313
    what typo?
    already explained to you thats not the case because under 21mph the ice is not turning and the regen is more
    when i apply the brakes i still here a little brake disc scratching even with mild braking.
    with B mode there is no disk brake at all and a little more regen.
    yes haha
  14. qbee42
    18,058
    3,076
    Northern Michigan
    You took my post out of context. I clearly stated that the advantage to B mode is that you can do it with one foot, or in other words while coasting. However, that said, absolutes absolutely work in this case. Maximum regen is limited by the ability of the battery to absorb energy, which is the same whether in B or D mode.
    Tom
  15. qbee42
    18,058
    3,076
    Northern Michigan
    This part is true. Pressing the brake pedal causes the brakes to move into a ready position. Because the pads are now touching, there is a small but finite increase in friction, which makes your statement factually correct even if not physically significant.
    The increase in regen is only an increase in coasting regen. Applying brake pressure will increase regen to the same level.
    Tom
  16. Dan.
    Dan. MPG Centurion
    387
    127
    Houston, Texas
    Agreed.
    I miss-understood your one-foot = coasting. I think of coasting as a no-foot driving technique B). Thanks for the clarifications... You are correct ;)
    11011011
  17. qbee42
    18,058
    3,076
    Northern Michigan
    Thanks. We can get into some real technical nick picking with the Prius, but then that's why it's so much fun for technical people.
    Tom
  18. Qlara
    Qlara New Member
    488
    This maybe an interesting "Did you know....?" info.
    However; how practical (or will you bother) to shift into B under 20mph everytime you're slowing down?
    Also, what's the reason to be afraid of using more Brake Padel action anyway?
    As stated, the Prius OS already programmed to do heavier regen while you're on slight braking action (to counter the real use of the brake pads)....But even that, Brake Pads are cheap to replace anyway!
    So if you're concerned about wear the brake pads, maybe you should be more concerned about 'wearing' out the gear-shift joystick when shifting to B everytime slower than 20mph. (It's an expensive item to replace) Suddenly, wearing out the brake pads will make more financial sense. :D
  19. Rangerdavid
    Rangerdavid Senior Member
    1,362
    52
    Boone, North Carolina
    Three Touring
    Nice thread, and I thought I'd interject, thanks to whomever put the "F" back in the title. I guess it wasn't just a Dutch thing.......... :)
  20. ken1784
    ken1784 SuperMID designer
    2,943
    1,381
    67
    Yokohama, JAPAN
    Below 7mph, there is no regen braking.
    Ken@Japan
