Shifter knob loose?
Discussion in 'Prius c Main Forum' started by priusmatty, Jun 23, 2016.
  1. priusmatty
    priusmatty Active Member
    304
    108
    Louisiana USA
    2020 Prius
    L Eco
    So on my new c, I noticed that the blue-topped shifting knob was turned a little to the left. I found that I could turn it back to straight. This bothers me a little. Does this mean my shifter is loose, or are they all like that? Thanks.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    I have a similar problem with my 2010 Gen 3. I probably could try to remove the knob, add a drop of glue, and put he knob back in place. But it doesn't happen often enough to really bother me.
  3. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
  4. Starship_Enterprius
    Starship_Enterprius Active Member
    319
    157
    Ottawa, Ontario
    2018 Prius Prime
    Yup, also happens to my 2010.
    But it does stay reasonably well if I don't shift too tensely.... so it's probably designed as an early warning device against road rage :cool:
    priusmatty likes this.
  5. Squeakasaur
    Squeakasaur Member
    106
    35
    22
    Seattle
    2016 Prius c
    The knob is a screw off. You can replace it with a different one if you wanted. Just turn it on nice and tight and you shouldn't have any problems with it.
    djdawn and priusmatty like this.
  6. Mr Incredible
    Mr Incredible Chance favors the prepared mind.
    955
    506
    Neb
    Just tighten it another turn. It simply screws off and on.
