Shifter (re)training
Discussion in 'Gen 5 Prius Main Forum' started by Will B, Sep 2, 2023.
  1. Will B
    Will B Active Member
    415
    356
    Denver
    2023 Prius Prime
    XSE Premium
    Curious if anyone else is having this problem:
    With my wife's 3rd Gen Prius, I didn't have much of a problem with the shifter on the dash. Yea, it was up for reverse and down for drive, but that didn't seem to have a learning curve to it.
    With my Gen5 I've scared myself several times with the same shifter setup. Now that it is on the center console it is push forward for reverse, push back for drive. That is throwing me off and I've shifted in the wrong direction several times. Seems like it should be the other way.
    Can't do much about it, hopefully I'll get that muscle memory sorted out quickly!
    will
    tovli likes this.
  2. theRob
    theRob Member
    92
    106
    2023 Prius
    Nope not at all. I had a CT200H and the shifter was like the 3rd gen Prius. Over and up for reverse and over and down for drive. It feels the same to me with the 5th gen Prius except the travel distance to get in gear feels a bit shorter (which I like). Non issue for me.
  3. Hammersmith
    Hammersmith Senior Member
    1,508
    1,518
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    The shift pattern is an interesting legacy, counter-intuitive pattern. I'm sure Toyota started doing it that way on hybrids because of the manual transmission shift pattern they use where reverse is up and to the left. But looking at it from a clean slate, forward should be up and reverse should be down because those directions match the actual movement of the car.
    What's getting me is there's something just a tiny bit different about either the brake pressure sensor or the timing of the brake allowing the shifter to engage that's different than the gen3. I'm getting lots of "Press the brake pedal to engage" when I try to put the car in gear. So my muscle memory from my gen3 must just be a tiny bit off from what the gen5 software is expecting. I'll get retrained eventually.
    tovli likes this.
  4. aforkosh
    aforkosh Active Member
    414
    263
    Oakland, CA
    2023 Prius
    The automobile convention is apparently that towards you is front and away from you means rear. For example, pulling the windshield wiper lever toward you activates the front washer; pushing it away activates the back window (or rear camera) washer if they exist.
    Sharol likes this.
  5. bisco
    49,842
    and yet on the hycam, it's a standard inline shifter. P, R, N, D, front to back
  6. Gokhan
    Gokhan Senior Member
    4,845
    1,907
    Paramount CA
    PRND2L is the convention for all automatic shifters.
    Montgomery and Mendel Leisk like this.
  7. Mr.Vanvandenburg
    1,173
    413
    2020 Prius Prime
    Guessing Toyota made it push left, then forward? Then the shifter springs back to the original position? Then its like the previous models, but on the console.
    #7 Mr.Vanvandenburg, Sep 2, 2023
  8. hill
    8,297
    This issue gave me a flashback. As a kid, it's reminiscent of my mom's 1960s Corvair shifter - mounted vertically on the dash.
    Nothing new under the sun
  9. HacksawMark
    HacksawMark Active Member
    449
    312
    Oregon
    2023 Prius Prime
    XSE
    Talk about retraining, how about a 1964 Dodge Polaris shifter.
    Montgomery and bisco like this.
  10. Trollbait
    11,691
    Many cars on US once roads had PNDLR automatic transmission shifters. That lead to issues, some safety. PRNDL was adopted to address those issues. Maybe D-N-R would make more sense than R-N-D, but the latter is now in the US vehicle code.
    Wonder Why Your Car's Shifter Goes P-R-N-D? There's a Great Reason
    Using a shifter that returned to a home position, I believe Toyota opted for having to move the shifter over before going to a gear to make accidental shifting less likely.
    This what Hondas are now rocking.
    Getting use to my parents each time I drive their car is annoying, but I do like the design.
    hill and bisco like this.
  11. bisco
    49,842
    our dil's oddysey had that, maybe even newer or older than that, with a pull up switch or two. i had to look at it carefully before selecting.
    new bolt is going to be interesting. owners are decrying the change from the original.
    original:
    update:
  12. Tom_06
    Tom_06 Active Member
    609
    142
    Newark, Delaware, USA
    The worst one was the Edsel "Tele-Touch" in the middle of the steering wheel. It was supposed to lock out a change from drive or reverse to park if the car was moving more than a couple mph. But a flaw let that happen if you went drive to neutral to park. BANG! The parking locking pawls would shear off. My dad had one, we never tried it. See: File:1958 Edsel Citation Teletouch Transmission (18997339216).jpg - Wikimedia Commons
    HacksawMark and bisco like this.
  13. bisco
    49,842
    must have been a software issue :cool: looks spectacular though!
