Shifter...What's the B for???
Discussion in 'Gen 2 Prius Main Forum' started by slowpoke, May 12, 2004.
  1. slowpoke
    slowpoke New Member
    48
    Okay, so I know what the R, N, & D stands for, but what about the B? When is this used?
  2. delrey
    delrey Member
    280
    SF Bay Area (East Bay)
    "B" stands for "Braking" -- to be used the way you would downshift to make the engine slow the car while driving down a long steep incline.
  3. peart75
    peart75 New Member
    104
    san diego
  4. richard schumacher
    7,663
    1,038
    United States
    And it's being discussed in the "Care, Maintenance and Troubleshooting" forum.
    (Anyone else think that there are too many forums on this website? And why are there separate priusonline and priuschat websites?)
  5. jasond
    jasond New Member
    165
    Boston
    Ooh ooh.. I can answer that one.
    Because they're run by different people.
  6. Danny
    Danny Admin/Founder
    7,093
    2,107
    1,174
    Charlotte, NC
    2013 Prius Plug-in
    I think I can help to answer it too :)
    There are so many forums here at PriusChat because it helps the site remain organized and unclutterred. If you're looking for a solution to a bluetooth problem, the first place you should look is the Audio & Electronics forum, if you're looking to throw some mud flaps on, one should check out the Appearance Modifications forum.
    When I created PriusChat it was basically because I was a member of the Yahoo Groups and was also a member of a few other message board-style communities. I saw that Prius owners & enthusiasts didn't have a place to create their own community. They were constrained by Yahoo on what they could do. So I created this site. It was only then that I found out about Priusonline. Their site was not very active and didn't have, in my opinion, what I wanted to see in an online community. Just like in the 2004-prius YG, I didn't see any leadership or any signs that things were going to change. As technologically savvy as most Prius owners are, I think they appreciate a place where what they suggest and say is listened to and that they have control over what goes on with the site.
    3 people like this.
  7. 2012PriusBoy
    2012PriusBoy New Member
    Crawfordsville, Indiana
    From What I UNderstand The "B" is to be Used when going down Steep Hills or Downgrades When Selector is in The "B" Mode it act's Like a Jake Brake Transferring more regenerative Braking Energy to the Battery than usual and helping slow Vehicle from the way I understood it....
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The Jake brake uses the engine to 'waste' energy so the friction brakes do not heat up as much, you need not use B unless you need to waste energy to make it down the hill without boiling the brake fluid. (That would be BAD) If you need it to make it down the hill alive, who cares what your mileage is?
    Someone at Toyota was too honest to call it L (it is not a lower gear ratio) but you use it when you would use L in an normal Automatic. (almost never)
    Automatic transmission - Wikipedia, the free encyclopedia
  9. usnavystgc
    3,159
    989
    Tucson, AZ
    Danny,
    I just want to tell you how much I appreciate this site and what you've done. The knowledge base here is invaluable and another benefit of owning a Prius. Keep up the great work and, don't change a thing. :)
    PS: I always wondered who started this site. Now I know.
